zhi_yi
Full Member level 4
lmb162afc-2
hi, please help me out, i am get stuck in interfacing the LCD using parallel port.
i use the LCD from topway, here is the datasheet :
www.topwaydisplay.com/Product/ pdf-manual/LMB162AFC-2-Manual-Rev0.1.pdf -
from what i read in many tutorials about access the LCD, what i have to do is first initialize the LCD, am i right? i tried it, but i don't know, why did nothing happen on my LCD after i sent the instruction to initialize it, and then set the cursor blink, i thought there must be something error in my hardware circuit, or maybe in my program, i hope someone would give me an example on access the LCD, it's not different from any other 2x16 LCD, all of the pins configuration is the same, and also the instruction. is it better i upload my circuit, and the program?
thank you ..
thank you ..
