Help me with installing Cadence 5
lovelyic
Junior Member level 2
spectre verilog license
i have got Base !c5 for linux and base Ldv 4 for linux
i have installed !c5 , should i install ldv at the !c5's directory or create a new directroy and how should i set CDS_INST_DIR and other variable?
thanks
mutipler path is OK
mutipler path is OK
This 2 ways do not give you the same result at all!! The big problem will occur if you install 2 or more packages, in this case ICxxx and LDVxxx, with not equivalent release version, since newer released versions alway have newer peripheral utilities i.e. JRE, cdsdoc, etc. I think IC5+LDV4 is OK to be installed in the same dir, while IC446+LDV4 is not. In Cadence's document said, you have to install the newer version software into the new dir because it can't completely replace the old version when it is installed in the same dir.
I think if you are not sure whether your 2 packages are compatible or not, it's a good idea to install them in difference dir. Just set your environment to be able to access all executable directory.
where can I get LDV4 for linux
Re: [help] C@dense install?
Can you help me get to tthe license for unnix?
thanks
I have IC5.0 and LDV3.4.
I want run mix-signal (spectre-verilog).
I get the license error message below:
Verilog/spectre Mixed-Signal Interface 2.0
You could not obtain mixed-signal license 32140.
Please check license setup.
Error! ERROR (LM -2): encryption code in license file
"/usr/tools/LDV34/share/license/license.dat" is
inconsistent (run 'lic_error -2' for more
information). Feature is 34510 [Verilog-LICENSE]
I have IC5.0 and LDV3.4 license.
But I don't know the mixed-signal license ???
Who can tell me soulation?
Sincerely.
Share
weather you can share your license ?
I you IC50 ,but have not license.
Thx
Sincerely.
I know IC5.0 License, but I don't have IC5.0
I need IC5.0 Binary for Linux, Solaris and HP-UX
