Help me with error when running psyn_shell in Synopsys Linux
nooby
Newbie level 6
Newbie level 6
synopsys linux question
All,
I met a question ,when I finished install the synopsys linux version,
I run psyn_shell. it report error, the following is the error message,who can help me to resolve this question .thanks!
/cad/tools/2002.05-SP2/linux/syn/bin/psyn_shell_exec: error while loading shared libraries: libncurses.so.4: cannot open shared object file: No such file or directory
thanks!
Re: synopsys linux question
The specified library cannot be found.
Possible reasons:
* a library (of this version/name) does not exist
-> check installed software via 'rpm -qa| grep curses'
and probably install missing package
* the library is installed at an unusual place (not very likely...)
-> check installation place via 'rpm -ql pkgname | grep libncurses'
* check if the link for the libncurses.so library is pointing to the
correct and existing library
HTH, RoZ
OOPs, forgot one thing
You can always specify a place to search for libraries via
export LD_LIBRARY_PATH="/search/this/path/specially/"
RoZ
make a link.
old problem. just search in this forum.
you have to install this package.
you can make a symbol link from libncurses.so.5
