unine
Junior Member level 1
- Joined
- Feb 11, 2004
- Messages
- 19
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Switzerland
- Activity points
- 181
3cm^2 antenna?
hello,
i'm in charge of designing an antenna with the dimensions 3x3cm.
i know you will tell me that it is absolutely impossible to build up an effective antenna with this size. but i'm not looking for the best gain, it should just be for demonstration.
does anybody have a good idea for a design? i tested a patch antenna with slots and short-circuit pins. the simulation (with @ds) was not too bad, but the fabricated antenna does not work as expected
thank you in advance!!
hello,
