Help me with designing a 220V sine wave generator
myouss
Newbie level 2
Newbie level 2
need un urgent help
Hello every body pls help me to build a 100KHz-500KHz , 220V sine wave generator using a 12Vdc power supply, is it possible to build such a circuit and is it so difficult or complex thank you all i am eagerly waiting for your answer Good bye
need un urgent help
Hi myouss,
I am sure it certainly possible to build a sine wave (100KHz - 500KHz)generator using 12V DC. For a less load it is even simpler.I am describe the method for lesser load.
Build a 12V 100KHz sine oscillator and connect the output to a step transformer. for example 9V to 220V step up transformer. For 100KHz transformer has to be designed.
So i am certain it can build the complexity depends upon the load.
regards,
Sudhir
    myouss
