TL0 DATA 08AH ;TIMER 0 - LOW BYTE
TL1 DATA 08BH ;TIMER 1 - LOW BYTE
TH0 DATA 08CH ;TIMER 0 - HIGH BYTE
TH1 DATA 08DH ;TIMER 1 - HIGH BYTE
P1 DATA 090H ;PORT 1
SCON DATA 098H ;SERIAL PORT CONTROL
SBUF DATA 099H ;SERIAL PORT BUFFER
P2 DATA 0A0H ;PORT 2
IE DATA 0A8H ;INTERRUPT ENABLE
P3 DATA 0B0H ;PORT 3
IP DATA 0B8H ;INTERRUPT PRIORITY
PSW DATA 0D0H ;PROGRAM STATUS WORD
ACC DATA 0E0H ;ACCUMULATOR
B DATA 0F0H ;MULTIPLICATION REGISTER
IT0 BIT 088H ;TCON.0 - EXT. INTERRUPT 0 TYPE
IE0 BIT 089H ;TCON.1 - EXT. INTERRUPT 0 EDGE FLAG
IT1 BIT 08AH ;TCON.2 - EXT. INTERRUPT 1 TYPE
IE1 BIT 08BH ;TCON.3 - EXT. INTERRUPT 1 EDGE FLAG
TR0 BIT 08CH ;TCON.4 - TIMER 0 ON/OFF CONTROL
TF0 BIT 08DH ;TCON.5 - TIMER 0 OVERFLOW FLAG
TR1 BIT 08EH ;TCON.6 - TIMER 1 ON/OFF CONTROL
TF1 BIT 08FH ;TCON.7 - TIMER 1 OVERFLOW FLAG
RI BIT 098H ;SCON.0 - RECEIVE INTERRUPT FLAG
TI BIT 099H ;SCON.1 - TRANSMIT INTERRUPT FLAG
RB8 BIT 09AH ;SCON.2 - RECEIVE BIT 8
TB8 BIT 09BH ;SCON.3 - TRANSMIT BIT 8
REN BIT 09CH ;SCON.4 - RECEIVE ENABLE
SM2 BIT 09DH ;SCON.5 - SERIAL MODE CONTROL BIT 2
SM1 BIT 09EH ;SCON.6 - SERIAL MODE CONTROL BIT 1
SM0 BIT 09FH ;SCON.7 - SERIAL MODE CONTROL BIT 0
EX0 BIT 0A8H ;IE.0 - EXTERNAL INTERRUPT 0 ENABLE
ET0 BIT 0A9H ;IE.1 - TIMER 0 INTERRUPT ENABLE
EX1 BIT 0AAH ;IE.2 - EXTERNAL INTERRUPT 1 ENABLE
ET1 BIT 0ABH ;IE.3 - TIMER 1 INTERRUPT ENABLE
ES BIT 0ACH ;IE.4 - SERIAL PORT INTERRUPT ENABLE
EA BIT 0AFH ;IE.7 - GLOBAL INTERRUPT ENABLE
RXD BIT 0B0H ;P3.0 - SERIAL PORT RECEIVE INPUT
TXD BIT 0B1H ;P3.1 - SERIAL PORT TRANSMIT OUTPUT
INT0 BIT 0B2H ;P3.2 - EXTERNAL INTERRUPT 0 INPUT
INT1 BIT 0B3H ;P3.3 - EXTERNAL INTERRUPT 1 INPUT
T0 BIT 0B4H ;P3.4 - TIMER 0 COUNT INPUT
T1 BIT 0B5H ;P3.5 - TIMER 1 COUNT INPUT
WR BIT 0B6H ;P3.6 - WRITE CONTROL FOR EXT. MEMORY
RD BIT 0B7H ;P3.7 - READ CONTROL FOR EXT. MEMORY
PX0 BIT 0B8H ;IP.0 - EXTERNAL INTERRUPT 0 PRIORITY
PT0 BIT 0B9H ;IP.1 - TIMER 0 PRIORITY
PX1 BIT 0BAH ;IP.2 - EXTERNAL INTERRUPT 1 PRIORITY
PT1 BIT 0BBH ;IP.3 - TIMER 1 PRIORITY
PS BIT 0BCH ;IP.4 - SERIAL PORT PRIORITY
P BIT 0D0H ;PSW.0 - ACCUMULATOR PARITY FLAG
OV BIT 0D2H ;PSW.2 - OVERFLOW FLAG
RS0 BIT 0D3H ;PSW.3 - REGISTER BANK SELECT 0
RS1 BIT 0D4H ;PSW.4 - REGISTER BANK SELECT 1
F0 BIT 0D5H ;PSW.5 - FLAG 0
AC BIT 0D6H ;PSW.6 - AUXILIARY CARRY FLAG
CY BIT 0D7H ;PSW.7 - CARRY FLAG
