kaszuky
Newbie level 3
I have finished the code for PIC16F887 using assembly language. However, when I send it to the uc, it does not work. I checked again and again, but I don't know where I am wrong. Hope somebody can help me figure out where I am wrong. Thank you very much for helping
My goal in this code is just send the data in the table to IC74HC595.
PIN 0 of PORT E is CLK
PIN 1 of PORT E is Latch
PIN 2 of PORT E is data.
That's all
Here my code:
;xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
LIST P=16F887
INCLUDE P16F887.INC
__CONFIG _CONFIG1, _LVP_OFF & _FCMEN_ON & _IESO_OFF & _BOR_OFF & _CPD_OFF & _CP_OFF & _MCLRE_ON & _PWRTE_ON & _WDT_OFF & _HS_OSC
__CONFIG _CONFIG2, _WRT_OFF & _BOR21V
CBLOCK 0x20
DELAYH
DELAYM
DELAYL
sended_data
pointer
check_8_bits
ENDC
ORG 0x00
MAIN
BANKSEL TRISE
MOVLW 0x00
MOVWF TRISE
MOVWF pointer
BANKSEL PORTE
MOVWF PORTE
read_again
MOVF pointer,0
CALL data_table
MOVWF sended_data
CALL send_595
MOVLW 0xFF
XORWF sended_data,0
BTFSC STATUS,Z
GOTO overflow
INCF pointer,1
CALL DELAY
GOTO read_again
overflow
MOVLW 0x00
MOVWF pointer
BCF STATUS,Z
CALL DELAY
GOTO read_again
send_595
BANKSEL PORTE
MOVLW 0x00
MOVWF check_8_bits
check_again
BTFSS sended_data,0
GOTO zero
GOTO one
zero
BCF PORTE,2
NOP
NOP
BSF PORTE,0
NOP
NOP
BCF PORTE,0
NOP
NOP
GOTO exit_595
one
BSF PORTE,2
NOP
NOP
BSF PORTE,0
NOP
NOP
BCF PORTE,0
NOP
NOP
exit_595
RRF sended_data,1
INCF check_8_bits
MOVLW d'8'
XORWF check_8_bits,0
BTFSS STATUS,Z
GOTO check_again
BCF STATUS,Z
BSF PORTE,1
BCF PORTE,1
RETURN
data_table
ADDWF PCL,1
RETLW b'00000000'
RETLW b'11111111'
DELAY
CLRF DELAYL
CLRF DELAYM
MOVLW h'2'
MOVWF DELAYH
WAIT
DECFSZ DELAYL
GOTO WAIT
DECFSZ DELAYM
GOTO WAIT
DECFSZ DELAYH
GOTO WAIT
RETURN
END
That's all
Here my code:
LIST P=16F887
INCLUDE P16F887.INC
CBLOCK 0x20
DELAYH
DELAYM
DELAYL
sended_data
pointer
check_8_bits
ENDC
ORG 0x00
MAIN
BANKSEL TRISE
MOVLW 0x00
MOVWF TRISE
MOVWF pointer
BANKSEL PORTE
MOVWF PORTE
read_again
MOVF pointer,0
CALL data_table
MOVWF sended_data
CALL send_595
MOVLW 0xFF
XORWF sended_data,0
BTFSC STATUS,Z
GOTO overflow
INCF pointer,1
CALL DELAY
GOTO read_again
overflow
MOVLW 0x00
MOVWF pointer
BCF STATUS,Z
CALL DELAY
GOTO read_again
send_595
BANKSEL PORTE
MOVLW 0x00
MOVWF check_8_bits
check_again
BTFSS sended_data,0
GOTO zero
GOTO one
zero
BCF PORTE,2
NOP
NOP
BSF PORTE,0
NOP
NOP
BCF PORTE,0
NOP
NOP
GOTO exit_595
one
BSF PORTE,2
NOP
NOP
BSF PORTE,0
NOP
NOP
BCF PORTE,0
NOP
NOP
exit_595
RRF sended_data,1
INCF check_8_bits
MOVLW d'8'
BTFSS STATUS,Z
GOTO check_again
BCF STATUS,Z
BSF PORTE,1
BCF PORTE,1
RETURN
data_table
ADDWF PCL,1
RETLW b'00000000'
RETLW b'11111111'
DELAY
CLRF DELAYL
CLRF DELAYM
MOVLW h'2'
MOVWF DELAYH
WAIT
DECFSZ DELAYL
GOTO WAIT
DECFSZ DELAYM
GOTO WAIT
DECFSZ DELAYH
GOTO WAIT
RETURN
END
