Help me with analyzing antenna microstrip with Matlab
jakjoud
Full Member level 2
Full Member level 2
Marrakech
analysing antennas
Please can you help me, I'll have a stage on analysing antenna microstrip with Matlab, can you show me some documents about, I wanna also if there is some tutoriels or examples.
thaks a lot
analysing antennas
you should indicate what a numerical method you prefer to use, MOM, FEM, FDTD or others.
Re: analysing antennas
What kind of simulation you would like to do?
analysing antennas
In fact I would like to have the radiation pattern of my antenna.
you can just plot the analytic formula of radation by MATLAB, but if you wabt a simulate an antenna with considering all effects an nonidealities, you must use a 3D simulator like HFSS.
i think for this problem you can check the book
ANTENNA THEORY - C.A. BALANI
enjoy
My expereince says that it is fully possble to simualte the radiation pattern using MatLab but it will defenetily need some work. What about is IE3D or ansoft. THey have student trial version availble. I may have an M-file for calculating the mutual ce and some other parameters, but not for the radaiton pattern.
Best Regards
Hi
I advice you to check this web site
file.21ic.com.cn then choose RF design folder it contain a book on antenna by matlab good luck
