Hello everybody,
I am a beginner user in Altium Designer program.
Can anyone help me and give me some tips in how I can draw the attached footprint pic for ACS758xCB using Altium Designer program?
The picture of PCB layout is provided with the component datasheet.
if you you place the pads from one side of the story will be in another oval. Usually companies that make printed circuit boards identify it as being boring to spend the cutter and do it correctly.
but actually as you can see in the picture attched there is missing information about the radius of the through hole pad ,
What do you think about this problem?
Can you give me some idea about how i can draw the pad???
I want to ask is the ACS758 will have the same radius of pad as the one you attched for ACS754?
Yep I thought it might be, though I think you will find the width is actually 0.078 (1.95mm) as 0.039 is the radius. The component legs are 1.50mm (+/- 0.10) as per the data sheet (search google for ACS758xCB, first hit should be data sheet).
The only thing that is missing is the metric dimensions for R1 and R2.
Thanks Bro, after checking the datasheets for ACS754LxCB and ACS758xCB and comparing the PCB Layout Reference View for both, It seems that the footprint you send for ACS754LxCB is same as the one I want for ACS758xCB.
