senthilkumar
Advanced Member level 1
help for sdram interface
hai,
i want to design a interface controller for the sdram chip HYB25L128160AC.
which have the separate address pin and data pin.
i saw one design in xilinx zbt sram verilog code.which have the multiflexed address and data line.
so how can i assign the pin to this design.
for example AD(0)-----------> ???
how is possible assign the two pin for the chip sdram.
my code look like this
* File Name: sdrm.v
* Version: 1.14
* Date: Sept 9, 1999
* Description: Top level module
* Dependencies: sdrm_t, sys_int
* Company: Xilinx
* Disclaimer: THESE DESIGNS ARE PROVIDED "AS IS" WITH NO WARRANTY
* WHATSOEVER AND XILINX SPECIFICALLY DISCLAIMS ANY
* IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR
* A PARTICULAR PURPOSE, OR AGAINST INFRINGEMENT.
* Copyright (c) 1998 Xilinx, Inc.
* All rights reserved
`include "define.v"
`timescale 1ns / 100ps
module sdrm (/*AUTOARG*/
// Outputs
sd_add, sd_ras, sd_cas, sd_we, sd_ba, Clk_SDp, sd_cke, sd_cs1,
sd_cs2, sd_dqm,
// Inouts
sd_data, AD,
// Inputs
Reset, Clkp, Clk_FBp, we_rn, data_addr_n
inout [(`DATA_MSB):0] sd_data, AD;
output [10:0] sd_add;
output sd_ras, sd_cas, sd_we, sd_ba, Clk_SDp;
output sd_cke, sd_cs1, sd_cs2;
output [3:0] sd_dqm;
input Reset, Clkp, Clk_FBp, we_rn, data_addr_n;
wire [(`DATA_MSB):0] sd_data;
wire [10:0] sd_add_op;
wire [(`DATA_MSB):0] sd_data_i, AD, AD_i;
wire [(`DATA_MSB):0] sd_data_reg;
wire sd_cke_o, sd_cs1_o, sd_cs2_o, sd_ba_op, ready_o;
wire [3:0] sd_dqm_o;
wire Reset, Reset_i;
reg [31:0] sd_data_o;
reg [(`DATA_MSB):0] sd_data_t, sd_data_R, AD_o;
reg [10:0] sd_add_o;
reg sd_ba_o, sd_cas_o, sd_ras_o, sd_we_o;
reg [3:0] sd_doe_n;
wire [3:0] sd_doe_np;
wire Clkp, Clk_FBp, Clk_SDp;
wire Clk_FB, Clk_i, Clk_j, Clk0A, Clk0B, Clk0C;
wire Locked2, Locked1, Locked_i, Locked_j, logic1, logic0, Clk;
wire sd_ras_op, sd_cas_op, sd_we_op, write_st;
wire AD_tri;
wire [(`ADDR_MSB):0] Add_reg;
reg [(`ADDR_MSB):0] AD_reg;
wire [1:0] rcd_c_max, cas_lat_max;
wire [2:0] burst_max, Act_st;
wire [3:0] ki_max;
wire [15:0] ref_max;
reg data_addr_n_reg, we_rn_reg;
wire data_addr_n, data_addr_n_i, we_rn, we_rn_i;
wire kid, auto_ref_in, auto_ref_out;
* Instantiation of sub modules. *
* sdrm_t = Top level for the SDRAM controller *
* sys_int = System interface module *
sdrm_t sdrm_t (.Locked1(Locked1), .Locked2(Locked2), .Clk_i(Clk_i),
.sd_ras_o(sd_ras_op), .sd_cas_o(sd_cas_op), .sd_we_o(sd_we_op),
.sd_add_o(sd_add_op), .sd_ba_o(sd_ba_op), .sd_doe_n(sd_doe_np),
.ready_o(ready_o), .Locked_i(Locked_i), .Locked_j(Locked_j),
.Add_reg(Add_reg[21:2]), .rcd_c_max(rcd_c_max), .kid(kid),
.auto_ref_in(auto_ref_in), .auto_ref_out(auto_ref_out),
.cas_lat_max(cas_lat_max), .burst_max(burst_max),
.Act_st(Act_st),.Clk_j(Clk_j), .write_st(write_st),
.ki_max(ki_max), .ref_max(ref_max), .rcd_end(rcd_end), .AD_tri(AD_tri));
sys_int sys_int (.Locked(Locked_i), .Clk_i(Clk_i), .data_addr_n_reg(data_addr_n_reg),
.data_addr_n_i(data_addr_n_i), .we_rn_i(we_rn_i),
.we_rn_reg(we_rn_reg), .AD_reg(AD_reg),
.Act_st(Act_st), .write_st(write_st),
.Add_reg(Add_reg), .sd_data_reg(sd_data_reg), .rcd_c_max(rcd_c_max),
.ki_max(ki_max), .ref_max(ref_max));
* Delay Lock Loops and Global clock buffers instantiation *
wire unused1, unused2, unused3;
//clock input to FPGA (Clkp), must go through IBUFG before entering DLL
IBUFG ibufg0 (.I(Clkp), .O(Clk));
//clock feedback from SDRAM for clock mirror (Clk_FBp),
// must go through IBUFG
IBUFG ibufg1 (.I(Clk_FBp), .O(Clk_FB));
//dll0 is clock mirror, provide SDRAM clock(Clk_SDp)
CLKDLL dll0(.CLKIN(Clk), .CLKFB(Clk_FB), .RST(Reset_i), .CLK0(unused1),
.CLK90(), .CLK180(), .CLK270(), .CLK2X(Clk0A), .CLKDV(unused2),
.LOCKED(Locked1));
//Clk_SDp is routed directly from dll0 to output buffer
OBUF_F_16 obuf0 (.I(Clk0A), .O(Clk_SDp));
//ddl1 provides internal clock to FPGA
//these clocks drive global clock buffer (BUFG) to get minimum skew
CLKDLL dll1(.CLKIN(Clk), .CLKFB(Clk_i), .RST(Reset_i), .CLK0(Clk0C),
.CLK90(), .CLK180(), .CLK270(), .CLK2X(Clk0B), .CLKDV(unused3),
.LOCKED(Locked2));
// Clk_j is the same as input clock (Clk_SDp)
// Clk_i is is multiplied by 2x
BUFG bufg0 (.O(Clk_i), .I(Clk0B));
BUFG bufg1 (.O(Clk_j), .I(Clk0C));
* IO pads Flip-flops and tri-state logic *
assign logic0 = 1'b0;
assign logic1 = 1'b1;
assign sd_cke_o = logic1;
assign sd_cs1_o = logic0;
assign sd_cs2_o = logic0;
assign sd_dqm_o[3:0] = {4{logic0}};
assign auto_ref_in = auto_ref_out;
always @(posedge Clk_i or negedge Locked_i)
if (~Locked_i)
begin
sd_data_o <= 32'hffffffff;
sd_data_t[31:0] <= 32'hffffffff;
sd_data_R <= 32'h00000000;
AD_o <= 32'h00000000;
AD_reg <= 32'h00000000;
data_addr_n_reg <= 1;
we_rn_reg <= 0;
end
else begin
sd_data_o <= #3 sd_data_reg;
//tristate signal is duplicated into 4 signals, each having 8 loads
//this helps reduce delay on sd_data_t
sd_data_t[31:24] <= #3 {8{sd_doe_n[3]}};
sd_data_t[23:16] <= #3 {8{sd_doe_n[2]}};
sd_data_t[15:8] <= #3 {8{sd_doe_n[1]}};
sd_data_t[7:0] <= #3 {8{sd_doe_n[0]}};
sd_data_R <= sd_data_i;
AD_o <= sd_data_R;
AD_reg <= AD_i;
data_addr_n_reg <= data_addr_n_i;
we_rn_reg <= we_rn_i;
end
if (~Locked_i)
begin
sd_add_o[10:0] <= 11'h000;
sd_ba_o <= 1'b0;
sd_ras_o <= 1'b1;
sd_cas_o <= 1'b1;
sd_we_o <= 1'b1;
sd_doe_n <= 4'hf;
end
else begin
sd_add_o[10:0] <= #3 sd_add_op[10:0];
sd_ba_o <= #3 sd_ba_op;
sd_ras_o <= #3 sd_ras_op;
sd_cas_o <= #3 sd_cas_op;
sd_we_o <= #3 sd_we_op;
sd_doe_n <= #3 sd_doe_np;
end
* IO pads instantiation *
IOBUF_F_12 iod0 (.I(sd_data_o[0]), .IO(sd_data[0]), .O(sd_data_i[0]), .T(sd_data_t[0]));
IOBUF_F_12 iod1 (.I(sd_data_o[1]), .IO(sd_data[1]), .O(sd_data_i[1]), .T(sd_data_t[1]));
IOBUF_F_12 iod2 (.I(sd_data_o[2]), .IO(sd_data[2]), .O(sd_data_i[2]), .T(sd_data_t[2]));
IOBUF_F_12 iod3 (.I(sd_data_o[3]), .IO(sd_data[3]), .O(sd_data_i[3]), .T(sd_data_t[3]));
IOBUF_F_12 iod4 (.I(sd_data_o[4]), .IO(sd_data[4]), .O(sd_data_i[4]), .T(sd_data_t[4]));
IOBUF_F_12 iod5 (.I(sd_data_o[5]), .IO(sd_data[5]), .O(sd_data_i[5]), .T(sd_data_t[5]));
IOBUF_F_12 iod6 (.I(sd_data_o[6]), .IO(sd_data[6]), .O(sd_data_i[6]), .T(sd_data_t[6]));
IOBUF_F_12 iod7 (.I(sd_data_o[7]), .IO(sd_data[7]), .O(sd_data_i[7]), .T(sd_data_t[7]));
IOBUF_F_12 iod8 (.I(sd_data_o[8]), .IO(sd_data[8]), .O(sd_data_i[8]), .T(sd_data_t[8]));
IOBUF_F_12 iod9 (.I(sd_data_o[9]), .IO(sd_data[9]), .O(sd_data_i[9]), .T(sd_data_t[9]));
IOBUF_F_12 iod10 (.I(sd_data_o[10]), .IO(sd_data[10]), .O(sd_data_i[10]), .T(sd_data_t[10]));
IOBUF_F_12 iod11 (.I(sd_data_o[11]), .IO(sd_data[11]), .O(sd_data_i[11]), .T(sd_data_t[11]));
IOBUF_F_12 iod12 (.I(sd_data_o[12]), .IO(sd_data[12]), .O(sd_data_i[12]), .T(sd_data_t[12]));
IOBUF_F_12 iod13 (.I(sd_data_o[13]), .IO(sd_data[13]), .O(sd_data_i[13]), .T(sd_data_t[13]));
IOBUF_F_12 iod14 (.I(sd_data_o[14]), .IO(sd_data[14]), .O(sd_data_i[14]), .T(sd_data_t[14]));
IOBUF_F_12 iod15 (.I(sd_data_o[15]), .IO(sd_data[15]), .O(sd_data_i[15]), .T(sd_data_t[15]));
IOBUF_F_12 iod16 (.I(sd_data_o[16]), .IO(sd_data[16]), .O(sd_data_i[16]), .T(sd_data_t[16]));
IOBUF_F_12 iod17 (.I(sd_data_o[17]), .IO(sd_data[17]), .O(sd_data_i[17]), .T(sd_data_t[17]));
IOBUF_F_12 iod18 (.I(sd_data_o[18]), .IO(sd_data[18]), .O(sd_data_i[18]), .T(sd_data_t[18]));
IOBUF_F_12 iod19 (.I(sd_data_o[19]), .IO(sd_data[19]), .O(sd_data_i[19]), .T(sd_data_t[19]));
IOBUF_F_12 iod20 (.I(sd_data_o[20]), .IO(sd_data[20]), .O(sd_data_i[20]), .T(sd_data_t[20]));
IOBUF_F_12 iod21 (.I(sd_data_o[21]), .IO(sd_data[21]), .O(sd_data_i[21]), .T(sd_data_t[21]));
IOBUF_F_12 iod22 (.I(sd_data_o[22]), .IO(sd_data[22]), .O(sd_data_i[22]), .T(sd_data_t[22]));
IOBUF_F_12 iod23 (.I(sd_data_o[23]), .IO(sd_data[23]), .O(sd_data_i[23]), .T(sd_data_t[23]));
IOBUF_F_12 iod24 (.I(sd_data_o[24]), .IO(sd_data[24]), .O(sd_data_i[24]), .T(sd_data_t[24]));
IOBUF_F_12 iod25 (.I(sd_data_o[25]), .IO(sd_data[25]), .O(sd_data_i[25]), .T(sd_data_t[25]));
IOBUF_F_12 iod26 (.I(sd_data_o[26]), .IO(sd_data[26]), .O(sd_data_i[26]), .T(sd_data_t[26]));
IOBUF_F_12 iod27 (.I(sd_data_o[27]), .IO(sd_data[27]), .O(sd_data_i[27]), .T(sd_data_t[27]));
IOBUF_F_12 iod28 (.I(sd_data_o[28]), .IO(sd_data[28]), .O(sd_data_i[28]), .T(sd_data_t[28]));
IOBUF_F_12 iod29 (.I(sd_data_o[29]), .IO(sd_data[29]), .O(sd_data_i[29]), .T(sd_data_t[29]));
IOBUF_F_12 iod30 (.I(sd_data_o[30]), .IO(sd_data[30]), .O(sd_data_i[30]), .T(sd_data_t[30]));
IOBUF_F_12 iod31 (.I(sd_data_o[31]), .IO(sd_data[31]), .O(sd_data_i[31]), .T(sd_data_t[31]));
OBUF_F_12 sda0 (.O(sd_add[0]), .I(sd_add_o[0]));
OBUF_F_12 sda1 (.O(sd_add[1]), .I(sd_add_o[1]));
OBUF_F_12 sda2 (.O(sd_add[2]), .I(sd_add_o[2]));
OBUF_F_12 sda3 (.O(sd_add[3]), .I(sd_add_o[3]));
OBUF_F_12 sda4 (.O(sd_add[4]), .I(sd_add_o[4]));
OBUF_F_12 sda5 (.O(sd_add[5]), .I(sd_add_o[5]));
OBUF_F_12 sda6 (.O(sd_add[6]), .I(sd_add_o[6]));
OBUF_F_12 sda7 (.O(sd_add[7]), .I(sd_add_o[7]));
OBUF_F_12 sda8 (.O(sd_add[8]), .I(sd_add_o[8]));
OBUF_F_12 sda9 (.O(sd_add[9]), .I(sd_add_o[9]));
OBUF_F_12 sda10 (.O(sd_add[10]), .I(sd_add_o[10]));
OBUF_F_12 sdb (.O(sd_ba), .I(sd_ba_o));
OBUF_F_12 sdr (.O(sd_ras), .I(sd_ras_o));
OBUF_F_12 sdc (.O(sd_cas), .I(sd_cas_o));
OBUF_F_12 sdw (.O(sd_we), .I(sd_we_o));
OBUF_F_12 sdcke (.O(sd_cke), .I(sd_cke_o));
OBUF_F_12 sdcs1 (.O(sd_cs1), .I(sd_cs1_o));
OBUF_F_12 sdcs2 (.O(sd_cs2), .I(sd_cs2_o));
OBUF_F_12 dqm0 (.O(sd_dqm[0]), .I(sd_dqm_o[0]));
OBUF_F_12 dqm1 (.O(sd_dqm[1]), .I(sd_dqm_o[1]));
OBUF_F_12 dqm2 (.O(sd_dqm[2]), .I(sd_dqm_o[2]));
OBUF_F_12 dqm3 (.O(sd_dqm[3]), .I(sd_dqm_o[3]));
* Processor Interface IO pads *
IBUF rst_b (.O(Reset_i), .I(Reset));
IBUF ads_b (.O(data_addr_n_i), .I(data_addr_n));
IBUF wern_b (.O(we_rn_i), .I(we_rn));
IOBUF_F_12 ad0 (.I(AD_o[0]), .O(AD_i[0]), .IO(AD[0]), .T(AD_tri));
IOBUF_F_12 ad1 (.I(AD_o[1]), .O(AD_i[1]), .IO(AD[1]), .T(AD_tri));
IOBUF_F_12 ad2 (.I(AD_o[2]), .O(AD_i[2]), .IO(AD[2]), .T(AD_tri));
IOBUF_F_12 ad3 (.I(AD_o[3]), .O(AD_i[3]), .IO(AD[3]), .T(AD_tri));
IOBUF_F_12 ad4 (.I(AD_o[4]), .O(AD_i[4]), .IO(AD[4]), .T(AD_tri));
IOBUF_F_12 ad5 (.I(AD_o[5]), .O(AD_i[5]), .IO(AD[5]), .T(AD_tri));
IOBUF_F_12 ad6 (.I(AD_o[6]), .O(AD_i[6]), .IO(AD[6]), .T(AD_tri));
IOBUF_F_12 ad7 (.I(AD_o[7]), .O(AD_i[7]), .IO(AD[7]), .T(AD_tri));
IOBUF_F_12 ad8 (.I(AD_o[8]), .O(AD_i[8]), .IO(AD[8]), .T(AD_tri));
IOBUF_F_12 ad9 (.I(AD_o[9]), .O(AD_i[9]), .IO(AD[9]), .T(AD_tri));
IOBUF_F_12 ad10 (.I(AD_o[10]), .O(AD_i[10]), .IO(AD[10]), .T(AD_tri));
IOBUF_F_12 ad11 (.I(AD_o[11]), .O(AD_i[11]), .IO(AD[11]), .T(AD_tri));
IOBUF_F_12 ad12 (.I(AD_o[12]), .O(AD_i[12]), .IO(AD[12]), .T(AD_tri));
IOBUF_F_12 ad13 (.I(AD_o[13]), .O(AD_i[13]), .IO(AD[13]), .T(AD_tri));
IOBUF_F_12 ad14 (.I(AD_o[14]), .O(AD_i[14]), .IO(AD[14]), .T(AD_tri));
IOBUF_F_12 ad15 (.I(AD_o[15]), .O(AD_i[15]), .IO(AD[15]), .T(AD_tri));
IOBUF_F_12 ad16 (.I(AD_o[16]), .O(AD_i[16]), .IO(AD[16]), .T(AD_tri));
IOBUF_F_12 ad17 (.I(AD_o[17]), .O(AD_i[17]), .IO(AD[17]), .T(AD_tri));
IOBUF_F_12 ad18 (.I(AD_o[18]), .O(AD_i[18]), .IO(AD[18]), .T(AD_tri));
IOBUF_F_12 ad19 (.I(AD_o[19]), .O(AD_i[19]), .IO(AD[19]), .T(AD_tri));
IOBUF_F_12 ad20 (.I(AD_o[20]), .O(AD_i[20]), .IO(AD[20]), .T(AD_tri));
IOBUF_F_12 ad21 (.I(AD_o[21]), .O(AD_i[21]), .IO(AD[21]), .T(AD_tri));
IOBUF_F_12 ad22 (.I(AD_o[22]), .O(AD_i[22]), .IO(AD[22]), .T(AD_tri));
IOBUF_F_12 ad23 (.I(AD_o[23]), .O(AD_i[23]), .IO(AD[23]), .T(AD_tri));
IOBUF_F_12 ad24 (.I(AD_o[24]), .O(AD_i[24]), .IO(AD[24]), .T(AD_tri));
IOBUF_F_12 ad25 (.I(AD_o[25]), .O(AD_i[25]), .IO(AD[25]), .T(AD_tri));
IOBUF_F_12 ad26 (.I(AD_o[26]), .O(AD_i[26]), .IO(AD[26]), .T(AD_tri));
IOBUF_F_12 ad27 (.I(AD_o[27]), .O(AD_i[27]), .IO(AD[27]), .T(AD_tri));
IOBUF_F_12 ad28 (.I(AD_o[28]), .O(AD_i[28]), .IO(AD[28]), .T(AD_tri));
IOBUF_F_12 ad29 (.I(AD_o[29]), .O(AD_i[29]), .IO(AD[29]), .T(AD_tri));
IOBUF_F_12 ad30 (.I(AD_o[30]), .O(AD_i[30]), .IO(AD[30]), .T(AD_tri));
IOBUF_F_12 ad31 (.I(AD_o[31]), .O(AD_i[31]), .IO(AD[31]), .T(AD_tri));
endmodule
iam the learner.
anyone help me.
thanks in advance.
hai,
* File Name: sdrm.v
* Version: 1.14
* Company: Xilinx
`include "define.v"
// Outputs
sd_cs2, sd_dqm,
// Inouts
sd_data, AD,
// Inputs
reg [3:0] sd_doe_n;
wire AD_tri;
wire [3:0] ki_max;
.LOCKED(Locked1));
.LOCKED(Locked2));
if (~Locked_i)
begin
we_rn_reg <= 0;
end
else begin
AD_o <= sd_data_R;
AD_reg <= AD_i;
end
if (~Locked_i)
begin
sd_ba_o <= 1'b0;
sd_ras_o <= 1'b1;
sd_cas_o <= 1'b1;
sd_we_o <= 1'b1;
sd_doe_n <= 4'hf;
end
else begin
end
endmodule
iam the learner.
anyone help me.
thanks in advance.
