Help me with 8051-based memory game with music in Assembly
ddtage
Newbie level 1
Newbie level 1
Hi guys..this is my project here...i'm havin some problems wit it..i'll be grateful if anyone can help me wit the source codes for this project..
Re: Need Help !!!
Start with "teaching" your 8051 how to play notes on a selected pin, say, P1.0 ..
For example, to play DO (262Hz) you will need to output a square wave of T=3.82ms, to play Re(294Hz) the time is 3.4ms and so on .. The other notes and their frequecies can be easily found googling ..
As you can see, you will need to use one of 8051's timers: Timer0 or Timer1 ..
Using Timer Interrupt create base time of, say, 100µs .. 10µs would be probably better, but for the sake of this excercise you can stay with 100 ..
If this 100µs routine is repeated for 38 times with P1.0 "L" and then 38 times "H" and the sequence is continously repeated for, say, 5s, the output will be DO ..
So, here: you will find out how to generate time interrupts with 8051 ..
Regards,
IanP
