Help me use F2812 to control a motor by PWM
Atiqkazmi
Hi all,
I am very new to ezdsp F2812 .can any one tell me how to use it for my task to control a sync motor by PWM.
When i connect it to the ccs it gives me the error
Error connecting to the target:
Error 0x80000200/-2082
Fatal Error during: OCS,
Device driver: Emulation Connection Loss Detected on Target CPU.
It is recommended to RESET EMULATOR. This will disconnect each
target from the emulator. The targets should then be power cycled
or hard reset followed by an emureset and reconnect to each target.
Sequence ID: 0
Error Code: -2082
Error Class: 0x80000200
I/O Port = 378
Board Name: F2812 eZdsp
Cpu Name: cpu_0
Abort: Close Code Composer Studio.
Retry: Try to connect to the target again.
Cancel: Remain disconnected from the target
Diagnostic: Run diagnostic utility.
Now can any one help to get out of this problem.
Looking forward for your help.
