reyge
Member level 4
hello! Attached are two circuit configuration that are similar except that one uses a single supply voltage and some capacitor and resistor values. Can someone explain what the right leg drive do? How does the OP97 accomplish this? Will there be a difference between the two circuit configuration aside from the difference in the power supplies?
I could really use some help. Thanks!
