Help me understand this negative feedback circuit
Katerina
Junior Member level 3
Athens, Greece
negative resistance
This circuit works as negative feedback when R1=8K2 and positive feedback for R1=18K.
The graph is what I get for negative feedback at 200Hz. I don't get it why is split in parts and why if I change the amplitude of the input some parts in both directions dissapear.
For positive feedback I get smitch trigger I think..
Can you help me understanding this circuit?
Re: negative resistance
I've done some progress with the circuit if anyone is interested. The non-linear areas of the graph are caused because of voltage saturation (also known as clipping) depended on the input amplitude. There is a maximun and minimum value of input signal to make the op amp work in the linear region.
If anyone has something more pls help.
negative resistance
actually the output voltage depends on the power suply.practically if you have Vcc +-15v then the maximun output voltage is Vcc-1=+-14volts before the voltage to saturate
    Katerina
You are right! In order to maintain the Kirchoff Law in the system!
