Help me understand some parameters on a datasheet
Matrix_YL
Full Member level 1
help me out datasheet
hi all
Who can explain these parameters represent for what ? such as Φddd Φeee and Φccc.And how to decide the pad diameter for my PCB?
thx in advance
Re: help me out datasheet
I usually make them equl to the max ball diameter. In your case that would be 0.3mm.
Hi VVV
At first ,thanks for your reply.
As you said max ball diameter,I think that would be Φb =0.7mm ,Are you sure the pad for my PCB would be Φddd=0.3mm ?
thx in advance
Sorry. You are absolutely right, 0.7mm. I don't know if this is the right way, but that is what I do.
