thenendo
Newbie level 2
I'm currently working my way through Horowitz and Hill's Art of Electronics, on my own with the student manual and wikipedia for help .
I have made it through chapter 1 relatively unscathed, my mind expanded, and I feel like I'm really starting to understand RC circuits. Except... voltage biasing, which comes up toward the end of the chapter as one of their examples of how useful diodes are. Let me real quickly set up the circuit...
This is a leading edge detector. The idea is that some varying voltage signal is applied at "in", say a square wave, and at "out" we get a voltage pulse for the leading edge of each input square wave. This works because on the leading edge of a square wave, dV/dt is very large, and so the impedance of the capacitor is very small, so the signal passes through it unmolested. If it's a leading edge, the signal is positive, and so it passes through the diode and the voltage at out is proportional to it. If it's a falling edge, no current gets through the diode, and the output is pulled low by R3. During every other part of the square wave (the peaks and troughs), dV/dt is very small, so the impedance of the capacitor is large, and very little of the signal gets through it; "out" is a constant LOW in between leading edges.
So this gives us an output of positive pulses coinciding with each leading edge of the input square wave, their amplitude proportional to the amplitude of the input, minus the voltage drop of D2. This last point is a problem, because if D2 has a forward voltage drop of 0.6V, then this circuit won't output anything on the leading edges of square waves with amplitude < 0.6V. Horowitz and Hill claim that this problem can be solved by adding another diode with the same voltage drop together with a constant positive "bias" voltage. Here's the circuit they give:
I can't quite see how this is a solution, and I was hoping somebody more knowledgeable than I am could explain where my reasoning goes wrong.
Let's work through what happens on the leading edge of a square wave with amplitude < 0.6V, say it's 0.3V. It's the leading edge, so the impedance of the cap is near zero. So the input signal passes through, and the voltage at point A is 0.3V. At the same time, because D1 (which they call a "compensation diode") has forward drop 0.6V and it's tied directly to ground, we know that the voltage at point B must be 0.6V (and hence the voltage drop across R2 is 4.4V). If B has 0.6V and A has 0.3V, current flows up from B to A with a voltage drop of 0.3V across R1. It seems to me that we have accomplished nothing... the voltage of 0.3V at A is less than the forward drop of D2 (0.6V), and so "out" sees nothing but ground.
Horowitz and Hill speak as if the 0.6V at point B (which they call "bias" without further explanation) somehow boosts the total across D2 so that a voltage of 0.3V (or something) will be left at "out". But how is this possible? I thought we never ADD voltages into a point, as if voltage were current. I can't reconcile what Horowitz and Hill say with Kirchoff's voltage law, so I must be doing something wrong. Any help is appreciated. Google is failing me :???:
