vincenc
Newbie level 3
I’m posting this question on physics forum, since I didn’t get the answer on electromagnetism forum… Sorry for doubling…
As a student I’m having difficulties understanding the Biot-Savart law…
The problem originates in basic definition of magnetic induction B and its relation with magnetization M and magnetic field H. The induction B in ferromagnetic materials can be written as:
B=n0*(H+M)
where H is the filed that is not affected by the presence of iron material and M is the material contribution to the field… The above equation can be rewritten in well known expression
M=x*H; (1+x)=nr B=n0*nr*H
So now the question – In above equations, H is the filed that would be produced, for instance, by the current in the vacuum, right? So, H is not affected by the presence of the iron? Thus, this filed can be calculated using Biot-Savart…. We can then calculate induction B, by simply multiplying this value with the material constants?
This is of course not correct, since this way all the geometry (flux path) is neglected. For example, if we would like to calculate the B in a tooth of the electric motor, then we would simple calculate H using Biot-Savart expression and multiply this value with n0*nr…. If above presumption would be correct, the FEM would not be needed at all….
Can somebody please point me where in above thinking I made a mistake?
Thank you in advance,
Vincenc
B=n0*(H+M)
Vincenc
