ccw27
Full Member level 5
Help on Bandgap Startup
For the startup circuit below used for bandgap I have found that for a fast ramping of supply voltage (10us) it takes a while for the bandgap voltage to reach steady state >10us, under different corners. However if you put a MOS cap at the current mirror this issue is solved. Can anyone explain why is this so? For slow ramping (5ms) of supply voltage the settling time is not an issue.
Thanks
Thanks
