heryrg
Junior Member level 1
Yet again i have a problem.
I need to trigger a pulse from a rising edge of a input signal. My input will go from 0 to about 2v. When the input changes from 0v to 2v i want to send a pulse of 1.3v or greater. The input will not go to 0 for longer then the impulse.
I've been playing around with 555 timer but with no luck. I built the attached circuit but no luck. Is there another way or is the attached circuit right ??
