help me to repair my USB
hoanglong
I have some broken usb memorys ! THeir PAL are the computer not recognize their driver so it can not work! I want to know why and how i can repair it?
i have just use usb memorys for one month. I also have a e-book has title " usb architecture ", pulishing by addison-Weslly! I don't know the book can help me solve this problem, can't it ?
i hope to get some advises from u!
best regard!
neo
best regard!
neo
Is the usb stick found correct in the device manager ?
(If your running XP you can format using the drive management tool.)
[/quote]Is the usb stick found correct in the device manager ?
(If your running XP you can format using the drive management tool.)[/quote]
i has checked usb is corrected in the device manager and it's ok!
i have noted that i have just used it for one month but now it can't work!
Check for a dirty connection or a BROCKEN JOINT.
clean the usb drive as well as your memory and then try. It happened to me also but it worked later
