Help me to make an FM Tx based on Crystal Oscillator be more stable
Re: FM Tx
Thanks alot for contribution, but sorry, it's a very complicated circuit with ultra much options that i don't care for the time being, I want it to be as simple as possible to be able to understand,
Thanks alot brother, :)
Ahmad,
FM Tx
For people who can't read french, you have to click the button at the top which opens the transmitter page in a new window.
Can anyone help me to make an FM Tx based on Crystal Oscillator to be more stable?
Describe your problem in more detail.
How much instability are you experiancing?
Over what time scale?
Is your problem due to changes in temperature?
If a crystal controlled transmitter is drifiting more than about 1 part per 100000 per hour then there is somthing wrong with it.
Re: FM Tx
In wide band FM TX you should use PLL for frequency stabilization and a crystal oscillator as reference.[/b]
Re: FM Tx
Fm needs to change the frequency in accordance with the signal. so it is hard to implement it with a crystal which generates a constant frequency.
