Help me to find a reference voltage for LDO test setup?
TheShoe
Newbie level 1
Newbie level 1
LDO Reference Voltage
Hi all -
I am trying to come up with a reference voltage for an LDO test setup. The voltage needs to be able to vary between 2.42 and 2.58V and have low noise specifications of 400nV/√Hz up to 1kHz and 100nV/√Hz between 1kHz and 100kHz.
I have not been able to locate any power supplies or any variable output LDO's with such low noise specifications.
Any suggestions?
Thanks,
TheShoe
Re: LDO Reference Voltage
Hello
You will not find any !
All you have to do is to use a REF IC like the REF02 + a buffer with a digital POT on the feedback line :
The REF02 deliver low noise 5V use the digital pot to trim the voltage and the budder to buffer it {in order to deliver some current )
All the best
Bobi
