Help me to choose good Math book!
BlackOps
Full Member level 5
Full Member level 5
AZERBAIJAN
g.v. kumbojkar
can you recommend me a good Math book?
i study electronics, and i need math of cuz, there are tons of links for the math books, but when i take a look at any of them i dont find them convenient for quick study or use... and i dont find them so good.
i need some book, which will also act as a handbook of math, for example... i do read analog electronics.. and i want to look at the differentiation in math book...
i need such a handy and convenient book, but which also shows everything from math!
which author and book u recommend?
thanks
Engineering MAthematics by Hargreaves, Davison and Croft
Advance Engineering MAthematics by Kreyzig
These r the two that I have found sufficient for my needs so far.
there is no good answear to your question. people can give you advice about a good book but you have to say which field of math you are interested in first.
mayyan
YES the above USER is absolutely right ..............IF you are in engineering(B.E) then YOU WILL HAVE ur work cut out because there are 5 sems of MATHEMATCIS for the ELECTRONICS branch.................THE most common book used is applied mathematics by G.V KUMBOJKAR FOR ALL THE 5 SEMS
You can see Arfken, it's a good book.
Can you give more details on the tittle of the book you recommend? Thanks
Search Amazon.com To Find The Book u Need
A good book for engineers is : Engineering Mathematics by Erwin Kreyszic
Cheers!
I agree too.Kreyszic is good Maths book for Engineers.
