Help me subtract V1 from M1*V1/M1+M2
The74namesofgod
Junior Member level 3
ok this should be easy but i cant figure it out im trying to
subtract V1 from M1*V1/M1+M2 and the ancer is (M2/M1+M2)*V1 so how do i get from the problem to the ancer thanks
in other words im trying to subtract V1 from V center of mass
Re: help with equation
Are you sure you typed your equations correctly? The first equation
M1*V1/M1 + M2
reduces immediately to V1+M2 since the M1's cancel.
Hi
I think you should use parentheses in the correct places.
V1 - M1*V1/(M1+M2) = [1 - M1/(M1+M2)]*V1 = [M2/(M1+M2)]*V1
Best
yes im sure. that is why i dont get it
What is the original equation?
1) [ (M1*V1)/(M1+M2)]
or
2) [ (M1*V1)/M1]+M2
Sol 1) [ (M1*V1)/(M1+M2)] - V1 --> (V1{M1-1})/(M1+M2)-->
--------> {V1*M1/(M1+M2)} - {1*V1/(M1+M2)}
Sol 2) {(M1*V1)/M1}+M2 - M1 --> (V1+M2-M1)
I just saw that this is a Mass Velocity problem. Can you write an equation that
relates M1/V1 to M2/V2 ? I think you need to introduce a new equation to get the
answer.
Cheers
Hope this helps
here is a link to mit Lecture its # 16 and the problem is at 36:30 to 38:30 you will need real player
high speed
low speed
this the step of solution of the equation
