[SOLVED] Help me solve this problem- Frequency for the given phase shift calculation.
iVenky
Advanced Member level 2
College Station, Texas
Given the function is
A(s)= [ 10 / (1+s/10000) ] ^3
What is the frequency at which the phase shift is 180 degree.
I tried using tan inverse formula but I didn't get the correct answer.
What's your answer?
You should write the transfer function in the form Re{A(s)}+jIm{A(s)} with s=jω.
Next step is to get the arg of the latter function to get the phase response,thus arg[Re{A(s)}+jIm{A(s)}]=arctan[Im{A(s)}/Re{A(s)}].
Finally equal the latter expression to 180 and solve for ω.
How do you know the correct answer since you didn't solve it?Is it a homework exercise and you just have the answer and try to confirm it?
After a little math and with the aid of mathematica i saw that there is no ω that satisfies your equation!
The correct answer is 1.732 x 10^4. But I didn't get that answer.
So,what answer did you get and in which way you tried to solve your problem?Give some clues to disguss and help you find the proper solution,with one-word answers what do you expect?
It seems like the "correct answer" is related to tan(60°).
Taking the transfer function in frequency domain,
H(jw) = 10/(1+jw/10000)^3)
Now, coming to basics of complex-algebra,
a complex number a + jb has a phase tan-1(b/a); extending this (a+jb)^3 has a phase 3*tan-1(b/a); you can prove this easily using euler's notation of a complex variable (a+jb=exp(jw)*r where w=tan-1(b/a); and so raising to the power 3, on both sides, you can find net phase = 3*tan-1(b/a));
similarly 1/(a+jb)=1/r*exp(-jw); and so the phase here, w'=-w=-tan-1(b/a);
Now just apply all these to your H(jw).
so the phase is -3*tan-1(w/10000) and equating it to -180
tan-1(w/10000)=60 degrees.,
so you get w=10000*sqrt(3)=1.732*10000 rad/s
Hello RS.
This is Venky.
For some strange reasons I had equated that to 1 instead of Pi. Should have slept while doing this.
Thanks anyway.
