Help me solve an inequality question
tomcenjerrym
Does anyone can solve the following equation?
|x − 1| = 1 − x
Thanks
Tom
Re: Inequality question
x=1 is the solution.... when x-1 is assumed to be negative we cannot obtain the solution....
just do a variable change y=x-1 and -y=1-x, so we will get Abolute value of y=-y so the only number that fits this equation is y=0 so if x-1=0 the solution is x=1.
The solution is : x= ] - ∞ 1]
This because any value of x less than or equlal to 1 would satisfy the equation
All of you must remind a well-known definition of the absolute number's value. It states the following:
|a| = a, if a>=0
= -a, otherwise
Therefore, your example |x − 1| = 1 − x results in the inequality:
x - 1 <= 0
x <=1
It's one of these unique rare cases when inequality is the satisfactory solution of the equation (usually, it's a number or some ones)
With respect,
Dmitij
x<=-1
Use |x|=x if x>0 and |x|=-x if x<0
thus the eqn presents no soluton for |x-1|>0.... But all values are satisfying the soln. for |x-1|<0
Thus x<=1 is the answer.....:)
| x - 1 | = 1 - x = - ( x -1 )
this means that x -1 < 0 (((( not x - 1 <= 0 )))) >>> some of the replies are wrong :(
>> x - 1 < 0 >>> x < 1
solution : (-∞ , 1 ]
