Help me solve a trig problem
lpaine1331
Newbie level 3
Newbie level 3
ok, its been along time. I n eed a little help getting started with this trig problem.
I have solved the problem all the way to this equation and I have to now solve for theta (the angle).
1.226 tan^2 theta + 24 tan theta - .575 = 0
How do i do this again?
thanks alot
Re: trig question
thanks alot
The soluation seems to be:
to bring the upon eqution into the form
aX^2+bX+c=0
"a" is can be removed bymultiplying it with "c" and at the final solution you will divide the result agian with "a"
while
X^2=tan^2 theta
a=1.226 -->
b=24
c=.575
continue...
Re: trig question
don't know if this helps but I plugged this in to my TI-89:
solve(1.226*tan(x))^2+24*tan(x)-.575=0,x)
the calculation resulted with:
x=92.9208 or x=1.37077 or x=-87.0782 degrees
Re: trig question
tan^2(θ)+24tan(θ)-0.575=0
tan(θ)=s
>>>> s^2+24s-0.575=0
>> s ≈- 0. 024, s≈-19.552
by using arctan == inverse tan
tan(θ) = -0.024 >>>> θ = arctan (-0.024) ≈-1.37°
tan(θ) = -19.552 >>> θ = arctan (-19.552) ≈-87.07°
Re: trig question
thanks alot
let tan Θ = x...
then 1.226 x² + 24 x - 0.575 = 0
x = (-24 ± √(24² - 4×1.226×(-0.575))) / (2 × 1.226)
= (-24 ± 24.058) / 2.452
x = 0.0237 or -19.6
Θ = 1.3576° or -87°
Re: trig question
Since the tangent function repeats every 180 degrees, the full solution is:
tan x = 0.0237
x = 1.36° + 180° * n
where n is any integer
and
tan x = -19.6
x = -87.1° + 180° * n
That explains the 92°.
-jonathan
Re: trig question
Sreida is right ,always remember whenever you met a situation like that where you can make a quadratic or cubic then go for that ,you will always get a derired output
Re: trig question
Its Right i think That's the only way.....
tan(θ)=s
>>>> s^2+24s-0.575=0
