Help me select ADC chip for measuring small changes in an analog ramp
fpmd
Newbie level 5
Newbie level 5
Hi, friends
Need your help here on ADC selection. Want to measure small changes in an
analog ramp (about 10ppm level). Need speed too (>1 MHz). What kind of ADC
chips do you recommend with good performance? Thanks in advance.
Re: ADC selection
go for recirculating ADC
ADC selection
do you mean the resolution is 10ppm. if your reference is 1v then the resolution is 10uv. is it right? that means 100dB SNR. and the data rate is larger than 1 MHz.
Re: ADC selection
renwl,
All you said is what I need. I can do a lot of averaging to reduce random noise though.
Thank you all.
ADC selection
You can try
ADS8482 or ADS1625 for speed function.
I am not sure you can measure 10ppm.
Re: ADC selection
Thank you. I will try ADI's AD7760 and AD7641 first. They look a little better.
