Help me program XC2S200 with Atmel parallel eeprom
mc&fpga
Member level 1
Member level 1
xc2s200 at17lv
hi
who has any experience in fpga programming with atmel eeprom,
i want to program xc2s200 with atmel parallel eeprom and want to use xc9536 or xc9572.anyone has idea.
Re: xilinx fpga programmer
Ehhmm..did you check app note 079 from xilinx?
thanks,xapp079 is useful and do you know can i replace at29c010 eeprom
Why don't you use the Atmel AT17LV series ?
it's an eeprom serial configurator, works fine.
you can also use a cpld convert the parallel to
serial
good luck
i think that is better to use a microcontroller whit a flash to upgrade your code.
Instead of 17LV there are the latest Serial prom from Xilinx.thei are cheapest.
Bye.
G.
