I have to come up with a clever design to align the two printouts for top and bottom layer, any suggestions welcome. Should be possible to align then placing the PCB between the two wothout any distorted image or scew.
Hi, just want your opinion if standard scanner glass is ideal for uv exposure. I've built a unit from a faulty scanner, but havent quite tested it out yet.FoxyRick said:Seriously, if you are making a single sided unit, find an old scanner.
