Help me make a current pulse on loop detector
infinity
Junior Member level 1
current pulse detector
I need make circuit for detect current pulses on loop. Loop has voltage source and loop current can be variable (0-1A). Current pulses are superimposed with aproximated value 15mA.
Any idea or inspiration?
Thanks!
Re: current pulse detector
In general you will have to use a high pass filter to separate the pulse from the background.
Try use a current transformer.
Hi.
When I need to measure a current in a circuit, I insert a resistor of small value in the circuit and read the voltage drop between the inserted resistor
by using the Op Amp. When the voltage at the driving port is important,
I used to use two lines; one is the voltage forcing line and the other is voltage sensing line. This method is widely used in the measurement equipments.
I wish this reply to be some idea to solve your problem.
Bye~~~
Use a rogowski coil.
