Help me make a cheap ZCD with 220V AC lines
boseji
Member level 1
Member level 1
Hello,
I wish to make a cheap ZCD for 220V AC Mains lines.
This is require for my isolated TRIAC firing.
I would require the output of this ZCD to be in 5V range and it should be able to detect both rising and Falling edges.
The PC817 Solution is elegant but requires 2 circuits to make a full detection. If there is some thing possible to do with a single output triggering at both the cycles.
Thanking you in Anticipation.
Regards,
Boseji
220v ac to 9v ac circuit
Hello,
I tried to simulate one circuit and found that it was optimal.
This used a 220v-to-9V AC transformer.
Please have a look. I have simulated this in LTspice where it gives good results.
Warm Regards,
Boseji
zcd detection
Hello,
You are right TekUT. But since I couldnt find any thing other than this opto so I used it.
Warm Regards,
boseji
