rommelm
Member level 1
Programmable delay
Guys, DO you have suggestions on what to use?
I need to introduce a programmable delay in my pattern Generator.. 1MHZ to 100MHz only... problem is.. Available IC is limited by the Pulse width of the signal.
If I will get the minimum possible pulsewidth (around 6.5ns), the stepping is very small, but to achieve a 1ns stepping my min pulse width is already around 20ns..
The IC I am considering is from Data delay devices.
https://www.datadelay.com
We used before maxim chip, the the output is the same...
do you have any better Idea?
