Help me interface a 320x240 LCD of LG322401 with a microcontroller
emb11
Newbie level 2
hyderabad
iam interfacing monochrome 320x240 lcd of LG322401 with a microcontroller,
ater initialisation no cusor or anything displayed.any one help me to find out my problem&send me a sample program asap.
pls send me a simulator to test my code for graphic lcd.
Re: 320x240 lcd
Hello!
Usually a good way to get attention is to start by saying "hello" or something
like this. Another thing is that when asking for something, "please" could be
another useful keyword to get help.
Then, if you are asking for free help, as a rule, never say "asap".
So apparently you need somebody to do you job. What is your budget?
Thanks,
Dora.
    emb11
Re: 320x240 lcd
hi,
Plz check this link it also contains downloadable code
Need to interface 320X240 graphics LCD
    emb11
Re: 320x240 lcd
Hi
1.Upload your schematic & LCD data sheet (or place a link)
2. If you think your hardware is Ok - try writing & reading from a scratch register
3. whether its works the problem may lay in your driver - try to add delays since most LCD hardware are very slow
All the best
Bobi
The microcontroller specialist
    emb11
Re: 320x240 lcd
hi,
iam attaching my code&details.This is a monochrome LCD320X240 interfacing with a simple microcontroller.
/* display_320240_test_program */
#include<stdio.h>
#include<reg51.h>
void write_comm(unsigned int);
void write_data(unsigned int);
void lcd_initialization(void);
void delay(void);
void delay2();
sbit Rst = P1^6;
sbit Wr = P1^4;
sbit Cs = P1^5;
sbit A0 = P1^1;
unsigned int a=0;
void delay2()
unsigned int K;
for (K=0;K<2500;K++)
void main()
lcd_initialization();
while(1)
write_comm(0x42);
delay2();
write_data(0x48);
Rst=1;
delay();
Rst=0;
delay();
Rst=1;
delay();
/**********system set***********/
write_comm(0x40);
write_data(0x30);
write_data(0x87);
write_data(0x07);
write_data(0x27);
write_data(0x2F);
write_data(0xEF);
write_data(0x28);
write_data(0x00);
/**********scroll***************/
write_comm(0x44);
write_data(0x00); //first layer address
write_data(0x00);
write_data(0xb1); //second layer address
write_data(0x04);
write_data(0x00);
write_data(0x00);
write_data(0x00);
write_data(0x00);
/****************csr form********/
write_comm(0x5d);
write_data(0x04);
write_data(0x86);
///**************cursor direction***/
// write_comm(0x4c); */
/***********hdot scr ************/
write_comm(0x5a);
write_data(0x00);
/************ovlay*************/
write_comm(0x5b);
write_data(0x01);
/***********disp on***************/
write_comm(0x59);
write_data(0x14);
/*********clear 1st layer****/
a=0;
while(a<0x04b0)
write_comm(0x46); //set cursor
write_data(a);
write_data(a>>8);
write_comm(0x42);
write_data(0x20);
++a;
/************clear 2nd layer***********/
a=0;
while(a<0x2580)
write_data(a);
write_data(a>>8);
write_comm(0x42);
write_data(0x00);
++a;
/*************command for lcd**********/
void write_comm(unsigned int cmd)
A0=1; //A0=1 is a command
P3=cmd;
Cs=0;
Wr=0;
delay2();
Wr=1;
Cs=1;
/*************data for lcd**********/
void write_data(unsigned int dat)
A0=0; //A0=0 is a data
P3=dat;
Cs=0;
Wr=0;
delay2();
Wr=1;
Cs=1;
/********************delay************/
void delay(void)
unsigned int b=0;
for(b=0;b<500;b++)
thank you
