neerom
Newbie level 1
lexical analyser
will u please help me with this code..... m not satisfied with this code...written in c++... but want to improve this code...please help me...
#include<iostream.h>
#include<conio.h>
#include<stdio.h>
#include<fstream.h>
#include<io.h>
#include<ctype.h>
#include<string.h>
#include<stdlib.h>
void readch();
void scanner();
void check();
void update(int);
void printerror();
void parser();
void whilest();
void forst();
void ifst();
void expression();
void statement();
void assignst();
//void printerror();
void inputst();
void outputst();
void subexpression();
void term();
void factor();
void declaration();
void variable();
enum basic_symbol{inc,plus,dec1,minus,divide,mul,semicol,lesseq,less,grteq,
great,equal,assign,stbrt,endbrt,stbrac,endbrac,noteq,not,
per,coma,and,or,ifsym,elsesym,intsym,fltsym,forsym,cinsym
,strconst,charsym,coutsym,whilesym,ident,intconst,charconst
,stringconst,apos,illeg,stringsym,startsym,illegst,coutop,
cinop,stsq,endsq};
basic_symbol token;
basic_symbol rwtable_token[11]={ifsym,forsym,intsym,cinsym,elsesym,charsym,coutsym,
whilesym,fltsym,stringsym,startsym};
char rwtable_string[11][11]={"if","for","int","cin","else","char","cout","while"
,"float","string","program" };
char ch;
int guidtable[9]={0,0,0,1,4,7,9,10,11};
int linenumber=0;
char name[50];
int intval;
char cval;
char stval[50];
ifstream f;
int flag;
char errortable [25][60]={"Error........starting brace missing {",
"Error........ending brace missing }",
"Error........start bracket missing (",
"Error........ending bracket missing )",
"Error........start symbol missing ",
"Error........Assign operator missing =",
"Error........Semicolon Missing ;",
"Error........Identifier missing ",
"Error........end array operator missing ]",
"Error........cout operator missing >>",
"Error........cin operator missing <<",
"Error........Extra Token ",
"Error........illegal Token ",
"Error........Wrong expression ",
"Error........No Initial Value Assigned ",
"Error........Inccremental Statement Missing",
"Error........No Conditional Statement ",
"Error........Multiple Declaration ",
"Error........Undefined Identifier ",
"Error........Array index out of bound ",
"Error........Wrong Array Index ",
"Error........Illegal Use of Array "
int ident_in=0;
enum id {var,constant,fun};
int var_flag=1; //it is used to check if there is a variable or function
int pos=1; //that will inc the no of position of node
char ident_n[30]; //name os ident
char t[6]; //type of the ident
int array_i=-1; // index of the array
id id_temp; //
basic_symbol id_kind; //use to store the type of identifier
int blk;
int array_insert=0;
struct node
char ident_name[30];
char type[6];
int array_index;
int isdec;
id i_id;
node *next;
int block;
class linklist
private:
node *head;
node *pointertopos(int);
int count;
public:
linklist();
void insert();
void multipleCheck();
void declared();
void print();
void checkBound();
linklist::linklist()
head=NULL;
count=0;
void linklist::insert()
if(pos>0&&pos<=count+1)
ident_in++;
if(pos==1)
node *x=new node;
x->next=head;
head=x;
strcpy(head->ident_name,ident_n);
//****for the defination of identifier*****//
if(id_kind==intsym)
strcpy(head->type,"int");
if(id_kind==charsym)
strcpy(head->type,"char");
if(id_kind==stringsym)
strcpy(head->type,"string");
head->isdec=1;
head->block=blk;
if(array_i!=-1)
head->array_index=array_i;
if(var_flag==0)
head->i_id=var;
else
head->i_id=fun;
x=NULL;
count++;
pos++;
strcpy(ident_n," ");
else
node *x=new node;
node *y=pointertopos(pos-1);
x->next=y->next;
y->next=x;
strcpy(x->ident_name,ident_n);
if(id_kind==intsym)
strcpy(x->type,"int");
strcpy(x->type,"char");
strcpy(x->type,"string");
x->isdec=1;
x->block=blk;
//strcpy->type=id_kind;
if(array_i!=-1)
x->array_index=array_i;
if(var_flag==0)
x->i_id=var;
else
x->i_id=fun;
//x->data=ele;
count++;
x=NULL;
y=NULL;
pos++;
else
cout<< "Wrong Pos"<<endl;
node* linklist:
ointertopos(int pos)
node * temp=head;
for(int c=1;c<pos;c++)
temp=temp->next;
return temp;
void linklist::checkBound()
node *temp=head;
if(array_insert>0)
while(temp==head)
if(strcmp(temp->ident_name,ident_n)==0)
if(temp->array_index>=array_i)
if(array_i>=0)
break;
else
update(20);
else
update(19);
temp=temp->next;
void linklist::declared()
node * temp=head;
if(ident_in>0)
while(temp!=NULL)
if(temp->isdec==1)
break;
else
update(18);
else
update(18);
temp=temp->next;
void linklist::multipleCheck()
node * temp=head;
if(ident_in>0)
while(temp!=NULL)
if( (id_kind==intsym&&(strcmp(temp->type,"int")==0)) || (id_kind==charsym&&(strcmp(temp->type,"char")==0))||(id_kind==stringsym&&(strcmp(temp->type,"string")==0)))
update(17);
temp=temp->next;
void linklist:
rint()
node * temp=head;
while(temp!=NULL)
cout<<" "<<temp->ident_name<<endl;
cout<<" "<<temp->type<<endl;
cout<<" "<<temp->array_index<<endl;
if(temp->i_id==var)
cout<<" "<<"variable"<<endl;
else
cout<<" "<<"fun"<<endl;
temp=temp->next;
linklist var_list;
void main()
f.open("c:\\abc.txt",ios::in);
if(!f)
{cout<<"file not found";
getch();}
else
readch();
scanner();
parser();
//var_list.print();
getch();
struct error
int errno[25];
int lineno[25];
int errorcount=0;
error array;
void update(int n)
//flag++;
array.errno[errorcount]=n;
array.lineno[errorcount]=linenumber;
errorcount++;
void printerror()
if(errorcount!=0)
int temp;
cout<<"\n\nFile compiled Total number of errors are : "<<errorcount<<endl;
cout<<"\t\t*****************************************\n\n";
for(int i=0;i<errorcount;i++)
temp=array.errno;
cout<<errortable[temp]<<" in line "<<array.lineno<<endl;
else
cout<<"\n\n\nFile Compiled No Errors"<<endl;
cout<<"\n\t\t*****************************************\n"<<endl;
cout<<"\t\t\t\t\t\t(c) DIOS Compiler"<<endl;
cout<<"\t\t\t\t\t\tdios@hotmail.com"<<endl;
void readch()
f.get(ch);
int allow_checking=0;
void scanner()
int a;
if(ch==eof(a))
token=illeg;
while(ch==' '||ch=='\t'||ch=='\n')
if(ch=='\n')
linenumber++;
readch();
else
readch();
//for a digit
if(isdigit(ch))
int i=0;
name=ch;
i++;
readch();
while(isdigit(ch))
name=ch;
readch();
i++;
name='\0';
intval=atoi(name);
token=intconst;
else
// for an identifier
if(isalpha(ch)||ch=='_')
int index=0;
name[index]=ch;
index++;
readch();
while(isalpha(ch)||isdigit(ch)||(ch=='_'))
name[index]=ch;
readch();
index++;
name[index]='\0';
token=ident;
int no=strlen(name);
for( int i=guidtable[no] ; i<guidtable[no+1] ; i++)
if(strcmp(name,rwtable_string)==0)
{token=rwtable_token;
break;}
if(token==ident)
strcpy(ident_n,name);
if(ident_in>0&&allow_checking==0)
var_list.declared();
else
allow_checking=0;
//else
//update(18);
else{
//for operators
switch(ch)
case '[':
readch();
token=stsq;
break;
case ']':
readch();
token=endsq;
break;
case '"':
readch();
int i=0;
token=stringconst;
while(ch!='"')
stval=ch;
readch();
i++;
if(ch=='\n')
token=illeg;
update(12);
break;
stval='\0';
readch();
break;
case '+':
readch();
if(ch=='+')
token=inc;
readch();
else
token=plus;
break;
case '\'':
token=charconst;
readch();
cval=ch;
readch();
while(ch!='\'')
token=illeg;
update(12);
readch();
readch();
break;
case '-':
readch();
if(ch=='-')
token=dec1;
else
token=minus;
break;
case '/':
readch();
if(ch=='/')
{ while(ch!='\n')
readch();
scanner();
else
token=divide;
break;
case '*':
token=mul;
readch();
break;
case ';':
token=semicol;
readch();
break;
case '<':
readch();
token=less;
if(ch=='=')
token=lesseq;
readch();
if(ch=='<')
token=coutop;
readch();
break;
case '>':
readch();
token=great;
if(ch=='=')
token=grteq;
readch();
if(ch=='>')
token=cinop;
readch();
break;
case '=':
readch();
token=assign;
if(ch=='=')
token=equal;
readch();
//token=assign;
break;
case '(':
token=stbrt;
readch();
break;
case ')':
token=endbrt;
readch();
break;
case '{':
token=stbrac;
readch();
break;
case '}':
token=endbrac;
readch();
break;
case '!':
readch();
if(ch=='=')
token=noteq;
else
token=not;
break;
case '%':
token=per;
readch();
break;
case ',':
token=coma;
readch();
break;
case '&':
readch();
if(ch=='&')
token=and;
break;
case '|':
readch();
if(ch=='|')
token=or;
break;
case '@':
case '?':
case '$':
case '~':
case '#':
case '^':
token=illeg;
update(12);
readch();
scanner();
break;
int allow_inserting_of_array=0;
void parser()
if(token==startsym)
scanner();
else
update(4);
if(token==stbrt)
scanner();
else
update(2);
if(token==endbrt)
scanner();
else
update(3);
blk++;
if(token==stbrac)
scanner();
while(token==intsym||token==charsym||token==stringsym||token==forsym
||token==ifsym||token==whilesym||token==cinsym||token==coutsym
||token==ident)
//use for the delaration
if(token==intsym||token==charsym||token==stringsym)
allow_checking=1;
allow_inserting_of_array++;
id_kind=token;//use for semantic
scanner();
declaration();
statement();
scanner(); //*/*//*/*/************************************
//using for all other statement
if(token!=endbrac)
update(1);
blk--;
printerror();
int arraychk=0;
void declaration()
if(token==ident)
strcpy(ident_n,name); //use for semantic
scanner();
if(token==stbrt)
var_flag=1;
variable();
else
update(14);
var_list.multipleCheck();
if(arraychk==0)
var_list.insert();
if(token==coma)
scanner();
if(token==ident)
scanner();
variable();
if(token==coma)
scanner();
if(token==ident) scanner();
variable();
if(token==coma){
scanner();
if(token==ident) {scanner();variable();}
else
update(7);
else
update(7); }
else
update(7);
if(token==semicol)
scanner();
else
update(6);
void variable()
if(token==stsq)
arraychk=1;
scanner();
array_i=intval;
var_list.checkBound();
if(token==ident||token==intconst)
subexpression();
else
update(21);
if(arraychk==1&&allow_inserting_of_array==1)
var_list.insert();
if(token==endsq)
scanner();/////////scanner look ahead
else
update(8);
array_insert++;
void statement()
{ ///for assignst
int control =0;//chaecking wheather there is any statement or not to handle semi col
if(token==ident)
scanner();
if(token==inc||token==dec1)
scanner();
control=1;
else
assignst(); //for assign st
if(token==ifsym)
scanner();
ifst();
control=0;
if(token==forsym)
scanner();
forst();
//print();
control=0;
if(token==whilesym)
scanner();
whilest();
control=0;
if(token==coutsym)
scanner();
outputst();
control=1;
if(token==cinsym)
scanner();
inputst();
control=1;
if(token==stbrac)
scanner();
while(token==forsym||token==ifsym||token==whilesym||
token==cinsym||token==coutsym||token==ident||token==intsym||
scanner();
declaration();
statement();
if(token==endbrac)
scanner();
else
update(1);
if(control==1)
if(token==semicol)
scanner();
else
update(6);
void assignst()
variable();
if(token==assign)
scanner();
else
update(5);
expression();
if(token==semicol)
scanner();
else
update(6);
void forst()
if(token==stbrt)
scanner();
else
update(2);
if(token==ident)
scanner();
if(token==assign)
assignst();
else
if(token==intconst)
scanner();
else
update(14);
/* if(token==semicol)
scanner();
else
update(6);
expression();
else
update(16);
if(token==semicol)
scanner();
else
update(6);
if(token==ident)
scanner();
if(token==assign)
assignst();
else
scanner();
else
if(token==intconst)
scanner();
else
update(15);
if(token==endbrt)
scanner();
else
update(3);
statement(); //there can be a++ in the loop then*********
/*if(token==intsym||token==charsym||token==stringsym)
scanner();
declaration();
void whilest()
if(token==stbrt)
scanner();
else
scanner();
if(token==stbrt)
update(11);
scanner();
else
update(2);
expression();
if(token==endbrt)
scanner();
else
update(3);
statement();
scanner();
declaration();
void outputst()
if(token==coutop)
scanner();
else
update(9);
if(token==stringconst)
scanner();
else
expression();
void inputst()
if(token==cinop)
scanner();
else
update(10);
if(token==ident)
scanner();
variable();
else
update(7);
void expression()
subexpression();
while(token==less||token==lesseq||token==great||token==grteq||token==equal
||token==noteq)
scanner();
if(token==ident||token==intconst||token==charconst)
subexpression();
else
update(13);
scanner();
term();
while(token==plus||token==minus||token==or)
scanner();
term();
void term()
factor();
while(token==mul||token==divide||token==and||token==per)
scanner();
factor();
void factor()
if(token==ident)
scanner();
variable();
if(token==stringconst||token==charconst||token==intconst)
scanner();
if(token==stbrt)
scanner();
expression();
if(token==endbrt)
scanner();
else
update(3);
if(token==not)
scanner();
factor();
void ifst()
if(token==stbrt)
scanner();
else
update(2);
expression();
if(token==endbrt)
scanner();
else
update(3);
statement();
scanner();
declaration();
if(token==elsesym)
scanner();
statement();
scanner();
declaration();
#include<conio.h>
#include<stdio.h>
#include<fstream.h>
#include<io.h>
#include<ctype.h>
#include<string.h>
#include<stdlib.h>
void readch();
void scanner();
void check();
void update(int);
void printerror();
void parser();
void whilest();
void forst();
void ifst();
void expression();
void statement();
void assignst();
void inputst();
void outputst();
void term();
void factor();
void declaration();
void variable();
cinop,stsq,endsq};
basic_symbol token;
char ch;
int linenumber=0;
char name[50];
int intval;
char cval;
char stval[50];
ifstream f;
int flag;
int ident_in=0;
id id_temp; //
int blk;
int array_insert=0;
struct node
char type[6];
int array_index;
int isdec;
id i_id;
node *next;
int block;
class linklist
private:
node *head;
int count;
public:
linklist();
void insert();
void declared();
void print();
void checkBound();
head=NULL;
count=0;
ident_in++;
if(pos==1)
node *x=new node;
x->next=head;
head=x;
if(id_kind==intsym)
head->isdec=1;
head->block=blk;
if(array_i!=-1)
if(var_flag==0)
head->i_id=var;
else
head->i_id=fun;
x=NULL;
count++;
pos++;
else
node *x=new node;
x->next=y->next;
y->next=x;
if(id_kind==intsym)
x->isdec=1;
x->block=blk;
if(array_i!=-1)
if(var_flag==0)
x->i_id=var;
else
x->i_id=fun;
//x->data=ele;
count++;
x=NULL;
y=NULL;
pos++;
else
node* linklist:
node * temp=head;
temp=temp->next;
return temp;
node *temp=head;
if(array_insert>0)
while(temp==head)
if(array_i>=0)
break;
else
update(20);
else
update(19);
temp=temp->next;
node * temp=head;
if(ident_in>0)
while(temp!=NULL)
if(temp->isdec==1)
break;
else
update(18);
else
update(18);
temp=temp->next;
node * temp=head;
if(ident_in>0)
while(temp!=NULL)
update(17);
temp=temp->next;
void linklist:
node * temp=head;
while(temp!=NULL)
if(temp->i_id==var)
else
temp=temp->next;
linklist var_list;
void main()
if(!f)
getch();}
else
readch();
scanner();
parser();
//var_list.print();
getch();
struct error
int errno[25];
int lineno[25];
int errorcount=0;
error array;
void update(int n)
//flag++;
errorcount++;
void printerror()
if(errorcount!=0)
int temp;
temp=array.errno;
else
void readch()
f.get(ch);
void scanner()
int a;
if(ch==eof(a))
token=illeg;
if(ch=='\n')
linenumber++;
readch();
else
readch();
//for a digit
if(isdigit(ch))
int i=0;
name=ch;
i++;
readch();
while(isdigit(ch))
name=ch;
readch();
i++;
name='\0';
intval=atoi(name);
token=intconst;
else
int index=0;
name[index]=ch;
index++;
readch();
name[index]=ch;
readch();
index++;
name[index]='\0';
token=ident;
break;}
if(token==ident)
else
allow_checking=0;
//else
//update(18);
else{
//for operators
switch(ch)
case '[':
readch();
token=stsq;
break;
case ']':
readch();
token=endsq;
break;
case '"':
readch();
int i=0;
token=stringconst;
while(ch!='"')
stval=ch;
readch();
i++;
if(ch=='\n')
token=illeg;
update(12);
break;
stval='\0';
readch();
break;
case '+':
readch();
if(ch=='+')
token=inc;
readch();
else
token=plus;
break;
case '\'':
token=charconst;
readch();
cval=ch;
readch();
while(ch!='\'')
token=illeg;
update(12);
readch();
readch();
break;
case '-':
readch();
if(ch=='-')
token=dec1;
else
token=minus;
break;
case '/':
readch();
if(ch=='/')
{ while(ch!='\n')
readch();
scanner();
else
token=divide;
break;
case '*':
token=mul;
readch();
break;
case ';':
token=semicol;
readch();
break;
case '<':
readch();
token=less;
if(ch=='=')
token=lesseq;
readch();
if(ch=='<')
token=coutop;
readch();
break;
case '>':
readch();
token=great;
if(ch=='=')
token=grteq;
readch();
if(ch=='>')
token=cinop;
readch();
break;
case '=':
readch();
token=assign;
if(ch=='=')
token=equal;
readch();
//token=assign;
break;
case '(':
token=stbrt;
readch();
break;
case ')':
token=endbrt;
readch();
break;
case '{':
token=stbrac;
readch();
break;
case '}':
token=endbrac;
readch();
break;
case '!':
readch();
if(ch=='=')
token=noteq;
else
token=not;
break;
case '%':
token=per;
readch();
break;
case ',':
token=coma;
readch();
break;
case '&':
readch();
if(ch=='&')
token=and;
break;
case '|':
readch();
if(ch=='|')
token=or;
break;
case '@':
case '?':
case '$':
case '~':
case '#':
case '^':
token=illeg;
update(12);
readch();
scanner();
break;
void parser()
if(token==startsym)
scanner();
else
update(4);
if(token==stbrt)
scanner();
else
update(2);
if(token==endbrt)
scanner();
else
update(3);
blk++;
if(token==stbrac)
scanner();
||token==ident)
allow_checking=1;
scanner();
declaration();
statement();
if(token!=endbrac)
update(1);
blk--;
printerror();
int arraychk=0;
void declaration()
if(token==ident)
scanner();
if(token==stbrt)
var_flag=1;
variable();
else
update(14);
if(arraychk==0)
var_list.insert();
if(token==coma)
scanner();
if(token==ident)
scanner();
variable();
if(token==coma)
scanner();
variable();
if(token==coma){
scanner();
else
update(7);
else
update(7); }
else
update(7);
if(token==semicol)
scanner();
else
update(6);
void variable()
if(token==stsq)
arraychk=1;
scanner();
array_i=intval;
subexpression();
else
update(21);
var_list.insert();
if(token==endsq)
else
update(8);
array_insert++;
void statement()
{ ///for assignst
if(token==ident)
scanner();
scanner();
control=1;
else
if(token==ifsym)
scanner();
ifst();
control=0;
if(token==forsym)
scanner();
forst();
//print();
control=0;
if(token==whilesym)
scanner();
whilest();
control=0;
if(token==coutsym)
scanner();
outputst();
control=1;
if(token==cinsym)
scanner();
inputst();
control=1;
if(token==stbrac)
scanner();
scanner();
declaration();
statement();
if(token==endbrac)
scanner();
else
update(1);
if(control==1)
if(token==semicol)
scanner();
else
update(6);
void assignst()
variable();
if(token==assign)
scanner();
else
update(5);
expression();
if(token==semicol)
scanner();
else
update(6);
void forst()
if(token==stbrt)
scanner();
else
update(2);
if(token==ident)
scanner();
if(token==assign)
assignst();
else
if(token==intconst)
scanner();
else
update(14);
scanner();
else
update(6);
expression();
else
update(16);
if(token==semicol)
scanner();
else
update(6);
if(token==ident)
scanner();
if(token==assign)
assignst();
else
scanner();
else
if(token==intconst)
scanner();
else
update(15);
if(token==endbrt)
scanner();
else
update(3);
scanner();
declaration();
void whilest()
if(token==stbrt)
scanner();
else
scanner();
if(token==stbrt)
update(11);
scanner();
else
update(2);
expression();
if(token==endbrt)
scanner();
else
update(3);
statement();
scanner();
declaration();
void outputst()
if(token==coutop)
scanner();
else
update(9);
scanner();
else
expression();
void inputst()
if(token==cinop)
scanner();
else
update(10);
if(token==ident)
scanner();
variable();
else
update(7);
void expression()
subexpression();
||token==noteq)
scanner();
subexpression();
else
update(13);
scanner();
term();
scanner();
term();
void term()
factor();
scanner();
factor();
void factor()
if(token==ident)
scanner();
variable();
scanner();
if(token==stbrt)
scanner();
expression();
if(token==endbrt)
scanner();
else
update(3);
if(token==not)
scanner();
factor();
void ifst()
if(token==stbrt)
scanner();
else
update(2);
expression();
if(token==endbrt)
scanner();
else
update(3);
statement();
scanner();
declaration();
if(token==elsesym)
scanner();
statement();
scanner();
declaration();
