osoenbolsa
Newbie level 3
I want to generate square wave oscillation using uc8051 with fixed duty cycle say 50% but i want to be able to change the frequency of oscillation from 1Hz to 2KHz by keying in the required value and make the uc generate it. 12MHz crystal oscillator is used. pls, i need help on how to do this.
I use asm code. Thanks all.
