Help me fix the electronics of a tig arc welder
Milan-Sr
Serbia
I have a question!
I have to repair a TIG ARC WELDER,problem is that all electronics in it is totally damaged.
I wont to use phase cotrol with SIEMENS TCA785 on primary side off transformer.
If anyone hes any experience with thih plese leave here sugestions,it might help me.
Thanks Milan
how tca785 works
It is easier to repair the unit.
Usually the hi voltage power section gets busted.
Explain the condition of the welder, maybe we can help.
Bye.
tig and pulse-tig datasheet
All electronic was destroyed,so I need some sheme that works.
Thanks,Milan
welder help
Milan-Sr said:
I have a question!
Thanks Milan
Do not post in all caps.
serbian welder
Hi
Is this possibly?!
problems of arc welders
To control power SCRs it is better to use n:n pulse transformers, as per attached applications from the TCA785 data sheet; pages 15 and 16 ..
application for tca785
Hi
I have not experience with pulse transformers. How to make those transformers?
Milan
