Help me fix I2C code in Proteus
neuralc
Full Member level 4
Full Member level 4
Hi all,
I'm trying to use the attached i2c c source files.
Simulating in proteus with 16f876a and fm24c16, and whe I send a byte (using SendI2C) in the StartI2C() the SEN are set to 1, that should esltimul the hardware to generate a start condition (SDA should go low), but the problem is the SDA doesn't go low neither the SSPIF are set again and I get an infinite loop ...
Some one can help??
ThX
NeuralC
* I2C Header file
* This file contains the function prototypes for the I2C routines defined
* in I2C.C.
#ifndef _I2C_H
#define _I2C_H
// Function Prototypes
char SendI2C(char, char, char*);
char GetI2C(char, char, char, char*);
char StartI2C(char);
char ReStartI2C(char);
void StopI2C(void);
#endif
* I2C Routines (2002.11.09)
* This file contains the I2C routines.
* Each routine's parameters are explained above the function declaration.
#ifndef _I2C_C
#define _I2C_C
#include "i2c.h"
* SendI2C
* I2CADD : Address of I2C slave device shifted left by 1 bit
* I2CBYTES : Number of bytes to send from I2CBUFFER
* I2CBUFFER : Pointer to a string buffer containing the bytes to send
* This subroutine transfers I2CBYTES bytes of data from the string pointed to
* by I2CBUFFER to the slave device at address I2CADD.
* Returns 1 : Send completed successfully
* 0 : Send failed
char SendI2C(char I2CADD, char I2CBYTES, char *I2CBUFFER)
char COUNT = 0;
char bSUCCESS = 1; // Assume successful transfer
if (StartI2C(I2CADD & 0xFE)) // Start transfer and indicate write
while (COUNT < I2CBYTES) // Loop until all bytes have been sent
SSPIF = 0; // Clear interrupt flag
SSPBUF = I2CBUFFER[COUNT++]; // Send byte
while (SSPIF == 0); // Wait until byte sent
} else
bSUCCESS = 0; // Indicate send failed
StopI2C(); // Stop the transfer
return bSUCCESS; // Return success indicator
* GetI2C
* I2CCOMMAND : > 0 indicates commanded receive, command in first byte of
* I2CBUFFER
* = 0 indicates normal receive
* I2CBYTES : Number of bytes to get from device and write to I2CBUFFER
* I2CBUFFER : Pointer to a string buffer, bytes read will be stored here
* This subroutine transfers I2CBYTES bytes of data from the slave device at
* address I2CADD and stores them in I2CBUFFER. If a commanded receive is
* indicated by I2CCOMMAND, the first byte of I2CBUFFER is written to the
* slave device before reading any data.
* Returns 1 : Get successful
* 0 : Get failed
char GetI2C(char I2CADD, char I2CCOMMAND, char I2CBYTES, char *I2CBUFFER)
char COUNT = 0;
char bSUCCESS;
if (I2CCOMMAND)
bSUCCESS = StartI2C(I2CADD & 0xFE); // Start transfer and indicate write
SSPBUF = I2CBUFFER[0]; // Send command byte
ReStartI2C(I2CADD | 0x01); // ReStart transfer and indicate read
} else
bSUCCESS = StartI2C(I2CADD | 0x01); // Start transfer and indicate read
RCEN = 1; // Initiate read sequence
while (SSPIF == 0);
I2CBUFFER[COUNT++] = SSPBUF; // Store byte in buffer
if (COUNT == I2CBYTES) // If we've read all the bytes
ACKDT = 1; // indicate we're done by no ack
else
ACKDT = 0; // else acknowledge the byte
ACKEN = 1; // Start acknowledge sequence
while (SSPIF == 0); // Wait until acknowledge complete
* StartI2C
* I2CADD : Address of I2C slave device (left shifted by 1 bit) + R/W bit
* This subroutine initiates an I2C transfer by sending a start condition and
* the slave device address, I2CADD.
* Returns 1 : Slave device acknowledged
* 0 : Slave device failed to acknowledge
char StartI2C(char I2CADD)
SEN = 1; // Initiate start condition
while (SSPIF == 0); // Wait until Start condition complete
SSPBUF = I2CADD; // Send address of slave device
while (SSPIF == 0); // Wait until address has been sent
if (ACKSTAT == 0)
return 1; // Return 1 if device acknowledged
else
return 0; // Return 0 if device didn't acknowledge
* ReStartI2C
* This subroutine sends a ReStart condition to the slave device at address
* I2CADD.
char ReStartI2C(char I2CADD)
SSPIF = 0;
RSEN = 1; // Initiate ReStart condition
while (SSPIF == 0); // Wait until start condition complete
if (ACKSTAT == 0)
else
* StopI2C
* This subroutine ends an I2C transfer by sending a Stop condition.
void StopI2C(void)
PEN = 1; // Send Stop condition
while (SSPIF == 0); // Wait until stop condition complete
#endif
proteus i2c sequence file
I don't analyze deap your code but , in general seams ok. Do you put the pull-up resistor at SDA and SCL lines?
Use proteus logs to view if the eeprom is receiving the start and stop conditions. I'll try to watch your code better during the night.
proteus sda scl
HUPS...:!!!!
Reading better the PIC16 model help, I view:
I2C not modelled - assignment to SSPCON2 only stores value.
I2C not modelled - assignment to SSPADD only stores value.
I2C not modelled - read of SSPCON2 only returns current value.
I2C not modelled - read of SSPADD only returns current value.
The PIC model does not model the I2C mode of the MSSP.
Writing to the SSPCON2 or SSPADD registers simply stores the written value in the register and does not instigate any other action.
Reading the registers returns their initial values or the value last written to them.
SO is explained.....
SDA, SCL, have pull up, thx Elavionic
ThX
NeuralC
proteus i2c
hi friend
a better example is already in proteus how to interface 12c with pic see sample file , altough you have get rid the problem by reading of pic16dll
help file
