Help me design an analog level shifter
tt38832
Newbie level 2
Newbie level 2
I need to design a voltage level shifter from dual supply input to single supply output. When input is -12V ,0V & +12V then output should be 0V,+6V & +12 respectively. Any recommendations on the circuit design for this level shifter?
Many thanks in advance
Re: Analog level shifter
A voltage divider (two resistors) between +12 and the input, perhaps an opamp buffer on the output.
+12V
   R
   *---- OUT
   R
  IN
Thank you so much. I will try it.
