nisha_s.priya
Newbie level 5
- Joined
- Aug 25, 2011
- Messages
- 9
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Tirunelveli, Taminnadu, India
- Activity points
- 1,334
Hi..
I want to design stacked patch antenna by this spec...
Parameter---------Min------------Max-------- Description
arU------0.6------ 1.4------ Aspect ratio for the upper patch
xU-------20mm----68mm--- The x-dimension for the upper patch
arL------ 0.6------ 1.4------ Aspect ratio for the lower patch
xL------- 20mm----68mm--- The x-dimension for the lower patch
tL------- 0.1mm---10mm----Thickness of the lower dielectric layer
tU-------0.1mm---10mm--- Thickness of the upper dielectric layer
εU-------1.0------7.0------ Relative permittivity of the upper dielectric layer (μ_r=1.0)
εL------- 1.0------ 7.0------ Relative permittivity of the lower dielectric layer (μ_r=1.0)
xfeed----0.2mm---10mm----Distance of feed probe from the edge of patch
These are my spec.. want to design stacked patch antenna... plz help me...
Thanks...
Thanks...
