ayyub
Newbie level 6
Hi guyz
I want RPM SENSOR guidence.I am actually working on Automation of Diesel Generator as my final year project.For that i am designing an ATS(Automatic Transfer Switch).In ATS when Main power goes off the ATS will transfer the Generator Output voltage on the load.The Output Voltage of Generator is only provided to the Load if the rated rpm is 1500(as i observed).
So i need rpm sensor that can be interfaced with PLC.The RPM sensor should have either analog or digital output so it will be easier to be interfaced with PLC .The Generator is showing RPM also but it is analog meter.
Guidence needed.
Guidence needed.
