mystery
Full Member level 2
Hi to all
I want to design a box which have the following properties.
The incoming voltage is 24V. The output voltage will be adjusted by a pot, and the output voltage will be between 0 to 24 V. And the output current will be about 10 A.
Could you help me to design such a system.
How will be the topology, Which ICs should I use? Any idea
thanks
thanks
