Help me design a photodiode detector and LED emitter circuit
sangkeetha
hi'
I'm going to design a simple fibre optic vibration sensor. This is how the system works:
LED illuminates the optical fibre and the light ray propagates inside the fibre and the change of transmission properties of the light propagating in the fibre will be detected by a photodiode detector.
I need the design of the photodiode detector and LED emmitter circuit, with model spec.
Thanx.
Re: fibre optic sensor
Everything depends on what are you going to transmit over fibre optic link ..
For example, for simple audio transmission, have a look at:
https://www.ozitronics.com/docs/k26.pdf
If you need fast data transmission, you may consider HFBR modules from Agilent Technologies ( data sheet can be downloaded from: **broken link removed** )
Regards,
IanP
    sangkeetha
I need the design of the photodiode detector circuit, with mode spec.
Thanx.
