bctang
Junior Member level 2
PWM Control Inverter
I need to design dc to ac inverter from DC +12Volt to AC 230. But i need to use PWM to control the inverter. I using "Sinusoidul Pulse Modulation" to control the MOSFET transistor.
When i using PWM to control the MOSFET transistor (inverter). The PWM signal will distortion. I have testing connect the AC load (lamp 230Vac/5W) , the output voltage from inverter drop to ~120Vac.
How to control or maintian the output voltage always 230Vac when connect AC-Load?
