HeiFelix
Member level 1
Small Antenna
I begin to design a antenna which must fit in size at 30X40mm on 315MHZ.
Is a coil of wire antenna always better than a PCB trace antenna, if I do not care the manufacture difficulty?
Should the wire be as long as near the wavelength/4=2.4m?
should the coil be flattened?
To catch more area and the wire length, the coil should be retangle. Is result better than a circular core?
If I use 0.5mm(diameter) wire to reach the length of 2.4m in 30X40mm area, How much gain will i get?
Help me!
Help me!
