brijmohan mohta
Newbie level 2
- Joined
- Jun 12, 2010
- Messages
- 2
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- india kolkata
- Activity points
- 1,293
guidance reqd for sourcing/design of 220 v single phase 50 hz supply to be converted
into: manually variable frequncy inverter.range 10 hz to 25 hz. voltage control is
not reqd.power at 25 hz 1 kw max. losses should be minimum as the inverter may
be reqd to run for almost 10 hours in a day intermittantly. swithing on and off will
be 7to 8 times in a day. cost control essential for wider application
brijmohan mohta[/url]
