Help me correct my LED blinking problem
nandini88
Junior Member level 2
why the LED keep blinking even thought i not press any button. pls anybody correct the code for me. thank you
unsigned short  i;
void main()
TRISB= 0xFF;
PORTB=0x00;
TRISD = 0x00; // PORTB as ouput
PORTD = 0x00; // Set port output as all 0's
while(1){
if(TRISB.F0==1) {  // Detect logical one to zero
for(i=0;i <50; i++){ //repeat 50 times
    PORTD.F0 = 0;   //switch on LED at PORTB pin 0
    delay_ms(150);  //short delay
    PORTD.F0 = 1;   //switch off LED
    delay_ms(150);
if(TRISB.F1==1) {  // Detect logical one to zero
for(i=0;i < 100; i++){ //repeat 100 times
    delay_ms(150);
if(TRISB.F2==1) {  // Detect logical one to zero
  for(i=0; i<1000; i++){ //repeat 1000 times
    delay_ms(150);
Re: led blinking problem
What does TRISB.F1==1 do? I don't understand that part of the code. Not familiar with this code.
I think you must write if(PORTB.F1 == 1) not TRISB and so the others.
You are testing TRIS which sets the port direction instead of testing the PORT.
Keith
thank alot for ur kind help. i know my mistake d.
---------- Post added at 10:09 ---------- Previous post was at 10:07 ----------
But it still same. keep blinking once supply is on. pls
What do you buttons do and where are they connected and how? You are detecting a 1 but buttons are often connected to 0V so you detect a zero.
Keith
have you changed it also to F2 and F0?
can you post your circuit schematic?
here i attached the schematic. if anything wrong pls correct it. im new learner.
thank you.
The problem is that your buttons have pullups so are always logic 1. Change you software to detect a zero on the button inputs instead of 1.
Keith
how to change. i not get u. pls... where i should change?
---------- Post added at 13:18 ---------- Previous post was at 13:12 ----------
ok ok. i got what u mean by. i changed d. now functioning well. thanks alot
---------- Post added at 14:26 ---------- Previous post was at 13:18 ----------
i having one more problem. now i want to count the number of led blinking by connecting it to optocoupler. so i think it involve interrupt code. so can u help me regarding to interrupt? every 1000 led blinking the count value have to increase by one and display the number of count in lcd.
thank you
