dkace
Full Member level 6
Hi all!
Long time no seing!!!
I have this conversion problem:
I have a unit that outputs 200 pulses for every 1 mile.
I have an interface which accepts 200 pulses for every knot ( 1nautical mile per hour) and outputs a RS232 signal equal to the speed in knots.
When I interface them I see in the output of the converter showing the 1/10th of the input I have from the primary unit. How I can multiply by 10 the output or convert the input from miles to knots ? ( second is more acceptable because I don't loose decimal digits).
Has anyone encounter this problem again?
Thanks,
D.
Thanks,
D.
