Help me configure NM7010A module for LAN using TCP
snaider
Member level 5
Member level 5
I NEED HELP ON CONFIGURING THE NM7010A. I JUST CAN'T GET THE INT SIGNAL CLEARED.
I AM USING THE I2C INTERFACE AND I SENT THE SYS_INIT COMMAND TO THE CR_C0 REGISTER. AFTER THAT, THE INTERRUPT SIGNAL WENT LOW (AS EXPECTED). BUT, WHEN I TRIED TO CLEAR THE INTERRUPT BY SENDING 0xFF TO THE IR REGISTER IT DIDN'T WORK.
COULD YOU PLEASE TELL ME HOW SHOULD I DO TO CLEAR THE INTERRUPT SIGNAL CORRECTLY?
I WOULD ALSO BE GRATEFUL IF YOU CAN FACILITATE ME SOME MATERIAL WITH AN EXAMPLE WIITH THE BASIC STEPS IN CONFIGURING THE MODULE TO WORK IN A LAN USNIG TCP.
