Help me choose proper coding technique
ramz
Junior Member level 2
Re: coding tech..
could any one suggest me the proper coding tech..
which tech to use.... beh or struc or data flow..
and wen touse
Added after 2 minutes:
i feel behavior is better..
but problem is unable to guess the expected hardware.
plz suggest me the solutin
Re: coding tech..
to use struc coding technique, first u should do build some user defined primitives,its not possible for big programmes.
in data flow, u cant use sequential type of instructions,
hence its always good to use behavorial
behavorial+dataflow=RTL coding
this is very popular rite now. plz correct me if i am wrong
thanks and regards
deepak
    ramz
Re: coding tech..
Hi ramz,
If u r writing a verilog code for synthesis, u must always have this thinking:
1) Think RTL
++ The functionality between registers
2) Think hardware
++ Think of topology implied by code
++ Do NOT write HDL models (behavioral)
3) Think synchronous
We normally use behavioral coding to describe the behavior of a black box circuit. The black box circuit can be any circuit (analog, digital or mixed signal)
While structure coding is use to describe the component in a design with interconnects between them. Example, a netlist circuit.
U can get better understanding by reading some verilog coding books. U can find it in E-book section.
Hope it helps and enjoy reading! :D
    ramz
coding tech..
I like here, i like all guy. All people is so generous~~
    ramz
